A couple Caterpillars moving a 100+ year old Oak TREE
   / A couple Caterpillars moving a 100+ year old Oak TREE #12
Thanks very cool vid.
   / A couple Caterpillars moving a 100+ year old Oak TREE #13
I too wonder why they pulled the way they did?? Maybe they had a reason?? But I would have either been pushing with the dozers, or at least pulling in the forward direction.
Cool none-the-less:thumbsup: 518,000 lbs is alot to move
   / A couple Caterpillars moving a 100+ year old Oak TREE #14
Cool Video. Wow, I,m sure a lot of tree huggers were happy to see that tree being moved, but at what cost ? Couldn,t the money have been put to many, many better uses ? What some people choose to do with other peoples money is head scratching. I might of missed it, but how much did that transplant cost ??? Is that an endangered type of tree, or was it saved because it was a hundred years old ?
   / A couple Caterpillars moving a 100+ year old Oak TREE #15
I think with the hoes were doing the pulling the dozers were lifting
   / A couple Caterpillars moving a 100+ year old Oak TREE #16
Must... not... say... powerjoke!
Pro tip: never pull backwards with a dozer. The more cautious folks don't even like to backdrag when on a slope. Also the excavators undercarriage are reversed! Those must be rentals.
They are sure to take a few years off the life of the under carriage. Idlers always at the front. Driving in reverse stretches the tracks. The undercarriages are designed to lay the track in front and roll over it.
   / A couple Caterpillars moving a 100+ year old Oak TREE #17
Agree they where trying to do some lifting with dozers. Would have been better to use the ripper bar for lifting if they had them.
   / A couple Caterpillars moving a 100+ year old Oak TREE #19
Wow that is so amazing. Great to see them save the tree. I wonder how it will adapt to the shock.
   / A couple Caterpillars moving a 100+ year old Oak TREE #20
interesting doing, placed a couple dozer drivers in the seat with direct view, driving backwards. and giving these 2 people a high up vantage point to actually see things and adjust things as needed. vs a spotter on the ground.
dozer tracks never really ever had a chance. they were the dead pull. to barely keep the tree moving. slow down to much, and tree runs over the dozer and you loose momentum, speed up and you just slip the tracks in the mud. no real way for the drivers of the dozers to even have a chance to get speed set just right, with constant excavators changing amount of force being applied to the dozers.
about all the excavators could do, was try and keep a half way even pace, between turning tracks and operating the bucket to help pull them along. and try there best to keep from bucking bronco themselves and more so the dozer drivers. actually felt a little sorry for one guy in dozer in video. looks like he nailed the ceiling in the cab of the dozer in one place of the video.
*rubs chin* it would be interesting to see actual traction control setup. in the larger machines. that allowed multi machines to be hooked together. through a wireless connection. so traction could be applied better across multi machines. other words, pulling other machines out that are stuck in the mud. to just using an extra machine to help do what ever. vs relying on seat of the pants driver experience and how good there team work is. i doubt there is a crew use to doing this everyday, exception for a given project, that only last so many days or weeks and it is over. and most likely not long enough for a team to fully get together and get things moving good. and clicking between all the team members.
2025 CFG Industrial JDCPF48-4400-FF Pallet Fork and Frame Attachment (A49462)
2025 CFG...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
toro turf sweeper (A50324)
toro turf sweeper...
1240 (A50490)
1240 (A50490)
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
