turnkey4099
Elite Member
w
Yes, common well and sump pumps will only build so much pressue - no fear of blowing out pipes.
Harry K
OP - you probably need to define if this is a submersible sump pump or a submersible well pump.
Either way, leaving them running (in water) with the outlet blocked will build up the pressure to a certian point and stop. The energy from the pump then is converted into heat which can be damaging. They can and will get quite hot. Once or twice I've nearly burned myself grabbing my jet pump that didn't get primed properly.
If it's not in water and running, see my previous response. That's even worse.
Harry K
