scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,348
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
Sorry - Dirtyoldman,
You are right for your pumps BUT wrong for a submersible, a sprinkler pump and a transfer pump on a fire truck are totally different setups than a submersible well pump. The above ground pumps CAN work without output for a while (3-5 minutes) and do not build a lot of pressure due to their design - single volute, single impeller setup.
Now submersible well pumps will build pressure and require some flow to stay cool. Most SUBMERSIBLE WATER WELL PUMP installations include a pressure relief valve alogn with the pressure switch that once that is exceeded it will start to bleed off water if the switch fails to stop the pump.
These pressuire relief valves are normally set at 70-80 PSI, as submersible well water pumps can generate 80-100PSI.
The pressure relief valves on submersible well pump systems allow some flow - usually around 1 GPM to prevent the pump from destroying itself.
Carl
Good Afternoon Carl,
Your right on the on fire dept pumps. Ive been a volunteer for almost 30 years, and when ever we have one of our engines in pump mode for more than a few minutes, if we are not flowing water, I usually recirculate the tank water through the pump. This keeps the pump housing, shaft packings etc cool, and prevents over heating. A simple thing to do rather than damage an expensive piece of equipment.
