Pitted Cylinder Rod: Repair or Replace
   / Pitted Cylinder Rod: Repair or Replace #11
The only gland is the rod seal in the cyl cap.
All the more reason to replace the rod if it's a single acting cyl (the pix doesn't show enough to determine that)
   / Pitted Cylinder Rod: Repair or Replace #12
Replace the rod and seal and be done with it.
I like to do the fingernail test to determine damage......after clean-up if you can feel it with your fingernails, then the seal will feel it too
I think also you've gone past the point of repair and should look into replacing the rod.......the bigger trouble may be the rusted/frozen gland.....hopefully it is easy to disassemble
Thanks for the replies.
I was able to get the frame broken down without killing myself. I got the nut off the top of the rod (3' of cheater pipe on an adjustable wrench). I was also able to get the 2 small bolts at the bottom loose - they hold the cylinder and the bottom spring bracket.
However, as noted in the above post, the collar that holds the seal won't budge. I have also tried a pipe wrench and the 3' cheater - nope. Part of the issue is that I'm generating enough force on that collar that it causes the rest of the frame to move and wiggle (as well as some flexing if the cylinder tube - it isn't attached anywhere except the bottom). So, I think I 'm going to take the cylinder out of the frame and try holding the cylinder with the pipe wrench, and a wrench on the collar. don't have lots of hope for this - pipe wrenches aren't the greatest in steel (a little hard so they slip). My also see if I can find a shop that can do it.
So the rest of the discussion may make the removal pointless.
The damage on the rod appears to be only pits (now). I took an emery cloth and a brillo pad to it and the it cleaned up ok.
Ok so some numbers to help with the discussion:
1) Seal is $11.50. Requires all this messing around to replace.
2) New rod is $325 + seal ($11.50) and requires about the same time/effort to replace as the rod.
3) Rechroming rod is about the same cost as a new ($275 + shipping) - same effort as replacement (getting the collar off)
4) Complete cylinder assembly is $622. Only need to install 1 plumbing fitting to get it to work.
So you see the range of outcomes here - $12 seal all the way up to $622 cylinder...
LOL I like this.
However, what I struggle with is, could I have gotten it done real cheap? Heck, anybody can just whack out all the parts and be moving again.
Mmmm, but the real point here was to be able to build fence...
Yep - single seal
   / Pitted Cylinder Rod: Repair or Replace #16
If it were me, I would try cleaning/smoothing the rod and a new seal. If it works u are good. If not then it would not be as hard to tear it down again and replace both parts. All u are loosing is a new seal. Are u a gambler?
   / Pitted Cylinder Rod: Repair or Replace #17
KY Gun Geek said:
Thanks for the replies....
I had a local hydraulic shop replace the seals, new rod for $99 last year on my HD8. Call around and see if a local shop can do it for you.
   / Pitted Cylinder Rod: Repair or Replace #18
Glad the rod cleaned up. Hope you were heavy with the soap pad and sparing with the emery. Abrasive removes sound material too easily. Try some heat on that cap. The old seal doesnt matter [and that and an O-ring I think I remember :confused2:] is all that is there other than metal.
larry
Talked to a local shop.
For less than I could buy a new rod and seals (which are around $350) - actually about $75 less, they made from stock a new rod, and replaced the seals. They also had the right tools to remove and reassemble the cap - to keep me from destroying it...
This includes a 1 year warranty on parts.
Now to get the thing back together.
   / Pitted Cylinder Rod: Repair or Replace #20
I guess the question is why you needed a new rod. :confused3:
2020 BOBCAT T76 R SERIES SKID STEER (A52705)
2020 BOBCAT T76 R...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
