Comparison A Question most of us ask when we're looking to buy a tractor,
   / A Question most of us ask when we're looking to buy a tractor, #21
I use my tractor mostly for mowing, but have a plow, brushhog, and so on. On my property I need 4WD just to get around for part of the year, and when mowing, without the front wheels acting as a break, will slide down some of my hills, so 4WD factors in for safety. I am building a small boom to go on the 3PH to use for lifting until I get the bucks for a new Coldwater loader.
My first tractor I used for 11 years with no FEL.. so I know How it is to get by without one, however there were many times I would say to myself how much easier it would be if only I had a FEL, Never really give much thought on how much easier having 4wd would been,
I guess by me learning to use and manipulate a 2 wd tractor with no FEL set ground for me to use my next 2wd tractor with a FEL and without the assist of 4wd. the key thing is ballast and traction to the rear of the tractor, as would be even for a tractor with 4 wd. I remember about 25 years ago when hired a man to dig out/ level the ground for our above ground swimming pool, It had rained the day before he was to do the work, I though he would call to cancel, although he showed up as scheduled, I advised him that it may be to wet for him to dig, His reply was "Nawww! I'll get it done" and showed me his Cut Kubota was 4X4 ... Now I have experience with owning 4X4 trucks and I know what a mess of things they can make playing around in mud, I was still a bit skeptical that he could do the job as wet as it was, As I watched he began to slip and slide but none the less still was able to get enough traction to dig, after about 1 hour he'd gotten the wet surface soil off and was down to the dry and only took about 1 hour more and he was done, So yes I know how useful having 4wd can be in certain situations and would have been no way a 2wd tractor could have done the job, I know! Example: early this past spring I was hired to spread out dirt that had been brought in from digging out a pond, was about 5 dump loads, very moist soil but not real soggy wet... at least wasn't to start out with, after breaking down and leveling out only one of the mounds the soil began to get mushy and packed to the tires I lost all traction, in fact I had to bucket my way out of the mess, I remember thinking how nice it would be if had a 4x4 tractor, But on second thought I said to myself, I would simply not take on this type of work again,;) for the most part my 2wd tractor has done anything I put it up against even digging a 4 ft deep into a bank-side x 30 ft area for a above ground pool, ( in Ga, red clay ) I might add:thumbsup: Though I did have to cut up the area with my disc-harrow first and several time after removing the clay 6" deep at a time,
Many examples and comparisons on how much more a 4x4 tractor With a FEL can do is hands down over a 2wd tractor with FEL, But comparing a ( 4x4 tractor only) to a 2wd tractor with a FEL ( for the money spent) But I must be wrong:, could'nt we do more everyday farming task with having a FEL, 4x4 is only a traction feature, Right! and I know some will say without traction what good is a tractor, we all know for hundreds of years our ancestors did their farming without the use of 4X4 tractors ;) and got the job done,
I'm sorry if it sounds like I'm defending the use of 2wd tractors, I'm just surprised that most folks would choose 4x4 over having FEL, But I'm sure the choice is of necessity, Now that I brought up the ancestor's tractors, Does anyone watch the classic tractor show? I happen to catch one yesterday, where this well known man , forgot his name, was hired to take factory built tractors and beef up the engine to produce more HP. before they were sold to the AG farmers, What I noticed about this particular tractor was that it had tandem rear wheels, I'm sure this was what they did back in the day to overcome traction issue, not too mention stability by it's oversize width,
   / A Question most of us ask when we're looking to buy a tractor, #23
Deep,
My last tractor was a 1951 Massey Harris 22k row crop gasser 2wd no dif lock plain jane tractor. I had a loader, back blade, 5' mower, 2 bottom plow and I thought I got around pretty well I scraped peoples drives in the winter and mowed for hire etc most all the normal tractor stuff.
I knew a 4wd would be the way to go but I had no idea just how well I would get around until I got one! I will never NOT have a 4wd tractor now and I certainly will NOT ever ever not have a loader. my .002 good luck in whatever you decide :thumbsup:
   / A Question most of us ask when we're looking to buy a tractor, #24
What is the classic tractor show called and on what channel does it come on? I have like every channel i could get. My guess is the RFD or rural channel or whatever? I rarely get to watch anything thats not on DVR due to limited tv time and so many shows!
   / A Question most of us ask when we're looking to buy a tractor, #25
FEL and 2WD would be my choice. I grew up on the farm with JD tractors 2WD and we added a trip style FEL to the JD 420 to do manure mostly - that made my day! Then we got a 1020 with FEL plus power steering and hydraulic bucket - that was a great tractor.
Today I run 4WD when I need it but most of the time 2WD - with a balanced machine weight wise, 2WD and chains can do a lot.
   / A Question most of us ask when we're looking to buy a tractor, #26
With over 100 inches of rain per year......I am glad my 186D has 4wd and I bought my tractor because of the FEL. Wouldn't be without either here in the beautiful Northwest!
I think the show is called "Classic tractor Fever" I'll have to look next time it's on for the channel playing, I happen to be channel surfing when I discovered it,:thumbsup:
   / A Question most of us ask when we're looking to buy a tractor, #28
For farm use I'd get the FEL and R1 tires and a good amount of rear wheel ballast rather than 4x4. No doubt I'd also like 4x4 but traction issues can be worked around more easily than the absence of an FEL.
   / A Question most of us ask when we're looking to buy a tractor, #29
Now with this 4wd tractor I load it on my trailer by simply setting my curled bucket on the deck for lift and flip her into 4wd and drive over the back of the trailer and on. No ramps to deal with but I am lazy I admit but 4wd and a loader saves me work just doing that. my .002 :)
   / A Question most of us ask when we're looking to buy a tractor, #30
I agree.
In summary - I couldn't accomplish half as much without a loader. I need the loader (and a tractor heavy enough to make the loader safe) more than I need 4x4 - if I were forced to choose only one, as stated in the original post.
8 1/2' X 14' STEEL DOVETAIL TRAILER (A58374)
8 1/2' X 14' STEEL...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
207276 (A52708)
207276 (A52708)
AUCTION STARTS HERE @ 9AM (A52708)
AUCTION STARTS...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
