Comparison A Question most of us ask when we're looking to buy a tractor,
   / A Question most of us ask when we're looking to buy a tractor,
It is clear to me that having a 4x4 tractor along with a FEL is the ultimate tractor to have:thumbsup: and my next tractor will likely have 4wd. ;)
I might have told this story before, but in case I haven't I really must:D.... as many of you know I am a housing contractor ( Interior Trim & remodeling ) or at least was:cool:.... well being in this field of business for 35+ years working along side of other contractors, ( landscapers, trenching,septic system installs etc,etc, ) I see it all and how well they handle their equipment, to say the least they know what their doing,... this subject has brought up a memory I have of an old black man I once knew back in the 80's .
I would guess his age to have been mid to late 60's , His job was to dig field lines for septic tank system's,
Here in Georgia the builders seem to build houses in what we called Cliffs, Houses with back yards that dropped off within 10ft of the house. We called these homes "Cliff hangers" 70-80 ft high in the back and several hundred feet down on a extreme steep slope...., well ya'll probably have guess by now and know where I'm going with the story..... This black man would use an old beat-up yellow Case backhoe/loader tractor ( 2wd ) to dig up-n-down /back-n-across the hillside of these properties, One after another day after day, and never needed the assistance of 4 wd. of course he rarely ever used rear-wd either because most of the time he would move his tractor about with only the FEL and Backhoe buckets, truly an amazing person to watch at work,:thumbsup: In fact I can also remember one time when a guy was attempting to landscape the short level area on at the rear of one the homes with a bobcat when the ground give way and flipped / rolled the bobcat down the steep hillside,........ While everyone was standing around trying to figure out how they were going to get the bobcat back up on it's wheels and out of the 300 ft gorge, The old black man got on his tractor and worked his way down within 50 ft of the bobcat, hooked a cable to it pulled the bobcat back over on it's wheels, Only stopping long enough to let the driver back into the bobcat to see if it would startup, fortunately the bobcat did start , The Bobcat driver made several attempts to drive it out but could not, the front end would lift up, he tried to drive it backwards up but still no success, It took the black man pulling with only his backhoe and FEL slowly working his way back up the hill moving only a few ft at a time with the bobcat in tow, there came a point when he could go no further, However the old man did manage to get it about half way up the hill where they could link enough chain together to pull it the rest of the way with a Bulldozer, It was a suspensful and truely amazing sight to watch, I can only think how much easier the old man could of had it if he had a modern day 4wd tractor:D ....... about 6 months later on into the middle of the next year, it was a hot mid 80's summer we found the Old black man laying feet up on a short foundation wall where he had set down to take a rest and apperantly fell over dead from having a heat stroke, I remember hearing the builders say, how surprized they were that he risk his life every day doing what he did and didn't kill himself while doing it, but yet lay over and died from having a heat stroke, they went on to say they will never find another person who could do what he could do, ......
   / A Question most of us ask when we're looking to buy a tractor, #42
That's a hard working tractor. Love the story about getting stuck in the fire! And I'm glad it had a happy ending! :thumbsup: Did I understand right that you had to pull it out with your truck?
Oh. One (very embarrassing) problem? I pushed a bunch of brush downhill into the fire, and overran the brush, getting stuck with the loader over the huge brush fire!!! I raised the loader up, and RAN for the truck and the chain. I got back real quick, as I'm sure you all understand! The loader was fine, but the front left tire was burning away.....that's right, it was ON FIRE. I put it out with the long hose I had down there to satisfy the powers that be when you burn, and towed the tractor out. Looking back at it, I'm not certain the 4wd would have gotten the tractor back uphill over the large brush pile. The valve stem was leaking air cause it was a little melted. I put the rest of a can of fix-a-flat in the tire, and it's fine!!
   / A Question most of us ask when we're looking to buy a tractor, #43
Yup....in a big hurry too!!! :) The brush I was on top of was keeping me from effectively moving the tractor with the bucket. Usually,lifting the bush hog and getting the traction to the rear wheels from the 500+ pounds of weight will get me through anything.....I tell you, I was sweating bullets! And that was *before* I saw the front tire on fire!!! It would have been all-day sweaty job feeding that fire by hand, but the tractor made it fun. And a fraction of the time too!
About 3 weeks ago after the state lift the burning ban I decide to burn a summer long accumulated scrap pile, when I burn I always keep the tractor close by with a full bucket of dirt to dump on it just in case;) after the pile burn down to what look to be nothing but hot ambers I decided to use the tractors bucket to stir it up, The unburned scraps started back up again while in the bucket, the bucket is out front far enough that I didn't worry about the tires, though I did have concern about the hydraulic hoses, on my particular loader out front short hoses connect the hard lines to the cylinders, I was afraid that these hoses might get heated enough to swell and burst, the one thing I could think of is seeing a tractor once at the local salvage yard burn to nothing no tires no hood not anything salvagable,... Perhaps this is how that tractor burned....:cool: >Stormpetrel < If you have the same on your loader you might want to take a look at them to be sure they didn't heat up or weaken from the extreme heat while sitting that close to the fire for that length of time,
   / A Question most of us ask when we're looking to buy a tractor, #45
I have a tractor near each place i have that i can borrow for that random task i would need a loader. My boom pole has lifted anything i have asked it to lift so far!
I used to use a Boom pole on my other tractor ( kubota ) but was limited to what I could lift, rarely could it lift anything over 200 lbs at the end without raring up the frontend:cool: ( even having used 200 lb. of weight on the front bumper ) most the time I wound up having to lift from about halfway of the boom and have to be careful while moving or it would swing into the rear of the tractor, I wound up selling the boom pole, When I got my YM and rigged it with a FEL, I could never find anymore use for a Boom pole, actually remember posting a thread on alternative uses for a Boom pole? and many Folks replied with brilliant idea's of how else to use them,...
Heck! just the other day My tractor impressed me once again when I moved a refrigerator with it's FEL .. traveled with it about 200 ft from my shop to the barn, it remind me again how nice having a FEL is:D Pushing that heavy fridge up hill on un-even terrain with using hand trucks would have been a pain for a man my age,:cool:
   / A Question most of us ask when we're looking to buy a tractor, #47
Funny you say moving a Fridge, i just put out for Hard Waste our old Double door unit with the FEL and forks, makes it an easy task.
   / A Question most of us ask when we're looking to buy a tractor, #48
If traction is your biggest issue, you need 4x4.
But for me lifting and carrying stuff is a principal use. A 'motorized wheelbarrow' so to speak.
The loader wasn't essential for this project but it sure helped. Those are buckets of roof gravel (with many loose nails) that I swept up to start dismantling this shed. The buckets were as heavy as I could carry across the roof and too heavy to carry down the ladder, filled. Using the tractor was like having a big dumb helper to do the (literal) heavy lifting.
Yup! another good example of how handy a front loader can be :thumbsup: and for the past month mine has gotten plenty of use when demoing and remodeling our rental house, Brought a construction dumpster out,.... and how do you think I loaded the dumpster? You guessed it:D
as I may have mentioned I've been working on rigging a FEL for a freind ( Kubota) I got it finished today and needed to deliver it.. what do you think I loaded it onto my trailer with... of course My loader:thumbsup: a Loader loading a loader;)
   / A Question most of us ask when we're looking to buy a tractor, #50
yep i filled a 31 cubic metre bin with mine, gee i tell you it made it easy. i have filled one by hand, never again....IMG_0154.jpg
2019 GALYEAN...
Kuhn Knight Verti-Max 5032 (A57148)
Kuhn Knight...
Linde E25C 5,000 lb Electric Forklift  Cushioned 4-Wheel, Indoor/Outdoor Use **Needs Batteries** (A59225)
Linde E25C 5,000...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
2021 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2021 Ford F-250...
