B3030 wheel spacers
   / B3030 wheel spacers #11
I would like to deviate from the original question. Does anyone know if the wheel (hub) dimensions are the same for a B2910 as the B3030? I have been on a search for these for clearance with chains.
If they happen to be the same, can I request the part number and/or source of these spacers.
Thank you.
Sorry to resurrect an older post, but stumbled across it while looking for something else. No, they are different. One is 150mm diameter and the other is 6" diameter. Close, but not the same. Different part numbers from the Kubota dealer, or aftermarket suppliers.
   / B3030 wheel spacers #12
Any chance you have the part numbers? I would like to order these for my B3030 but having an issue locating them. Well, truly, I got an order but it was a single spacer, without studs or bolts, at ~198mm wide. It was to be for this tractor but I am not sure and would like to get some confirmation before I order another $190 spacer for the other side.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
PALLET OF (2) TRIPAC THERMOKING UNITS (A50854)
PALLET OF (2)...
