Kerosene in tractor
   / Kerosene in tractor #11
Back in the day kerosene/no. 1 diesel was the preferred fuel for large, stationary diesel generator sets, say from 50KW to 1500KW. These sets may have large fuel tanks that hold up to thousands of gallons. The thinking was that for long term storage of possibly several years with only periodic maintenance runs, the kerosene/no.1 diesel would hold up better and have less algae.
However, in recent years some of the major engine manufacturers have made noises that they would not honor the engines' warranty if anything but no.2 diesel were used. Check your owner's manual.
As for me, I buy no. 2 road diesel 5 gallons at a time. I like to find a pump station where I can get both gas and diesel at the same pump station. I find the off-road diesel pump stations are outback and inconvenient or some guy with a 500 gallon tank is in line ahead of me.
   / Kerosene in tractor #12
Is there no savings on off road diesel down there? Up here, it is well worth the wait. Just go to a high volume station.
   / Kerosene in tractor #14
At the local airport they run all the diesel powered equipment, including a large bucket loader, on jet fuel.
We did this this when I was stationed in Rota Spain. I had an old diesel gen set at the place I rented off base and I ran OK on Jet Fuel. Adding the 2 cycle lube sounds like a good idea if running with kerosene in a pinch but as noted diesel is preferred and cheaper. There is a difference in 40 year old diesel engine fuel requirements vs 2013 diesel engines I am sure so I would be careful with the new stuff IF I owned any.
   / Kerosene in tractor #16
i think my manual reccomends adding a % of it based on the temp.
   / Kerosene in tractor #17
i think florida may have just got winter mix diesel.
filled up a bunch of work trucks today at the same pump we normally use for onroad.. and it 'smells' different.. quite different.. lighter odor.
they still blend #1 and #2?
   / Kerosene in tractor #18
I'd bet you never have to clean the injectors on the diesel equipment. The fuel may also have good anti-icing since Prist or something similar is probably present. It's a win-win with 'no bugs & no icing.' How does jet fuel compare in price since there are no road taxes?
   / Kerosene in tractor #19
Jet fuel can be very expensive to the retail buyers, it usually sells for between six and seven dollars a gallon but there is a huge mark up. I think the airport owners buy it for less than diesel fuel would cost.
You are right about jet fuel being very clean, it gets filtered multiple times before it gets dispensed from the truck. "Prist" is an additive that makes any water born contamination settle out of solution so it will sink to the bottom of the tanks where it can be drained off by using the sump drains.
   / Kerosene in tractor #20
DEGMME mmm.. good stuff! :)
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Galvanized Livestock Gate (A55218)
Galvanized...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
