New JD 3520 photos
   / New JD 3520 photos #11
You're not planning to get dirt on that shiny new thing, are you? :D
Congrats! I know how thrilled I was with my 'new' (2005) 3120 TLB, not sure I'd survive the excitement of a brand new machine.
   / New JD 3520 photos #12
Great looking setup! I got my 3320 about 2 months ago and love it. The 3 series tractors seem like the perfect size. I also got the MX5 bushcutter and have been impressed. Let me know how you like it.
After wrestling with a few different implements, I quickly found the iMatch would be worth the money and purchased one. It's been nice to back up and hook up in a matter of seconds.
How do you like your TNT kit? I was thinking about getting one. Where did you get yours?
Thanks!
   / New JD 3520 photos #13
Congrats. I went from 755 to a 3320 and it was night and day! Extra ponies of a 3520 is another plus. I always was amazed at what I could do with the 755 so I'm sure you will be in the same boat and then some!
   / New JD 3520 photos #14
Nice looking ride. Congrats! :thumbsup:
   / New JD 3520 photos #15
Ummy! Congrats!
I vote for Imatch too. I set up all my attachments to fit it and once that's done changes are easy.
   / New JD 3520 photos #16
I got iMatch and the top'n'tilt package after 14 years of wrestling with implements that needed manual hookup on my little JD755.
Photos attached of the cutter and box blade - shiny green, and not a mark on them yet. Oh, the driveshaft resting on the box blade belongs with the cutter - it just happened to be there when the picture was taken.
Sooo, a driveshaft equipped box blade. I heard Deere was experimenting with new ideas and a few " select " buyers would get them to try out. You lucky dog ! You can tell us.... how does it work and can we modify our last years model to the same specs ? I won't tell anyone. :)^)
   / New JD 3520 photos #17
Geezer;
Thanks for the picture of the grille guard.. Now I feel obligated to update mine. Wouldn't you know after it is shiney painted and working fine the new style appears out of no where. I have been making some trails and moving brush. It crossed my mind several times to protect the expensive hood / lights.
Aigeezer,
How do you like your I-Match system so far?... wondering if you have to buy the bushing kit for each implement that you want to use?.
Sorry, Whisper35, I didn't see your post until now.
I wondered about the same thing. The short answer seems to be "no". It's easy to grab bushings from an unused implement and put them on - sort of like moving drilled pins from one to another. It's convenient to have them on each implement ready-to-go though.
At this early stage, I'm not wild about the iMatch. I also wasn't wild about the Pat's Quick Hitch I bought for my old JD755. In both cases, the problems might be just new-gear stiffness and my lack of experience, so... ask me in a year. For now, it isn't saving me any time but it definitely is saving me some physical grunt-work manhandling implements into position. Many of my implements are older and may not be iMatch-compatible, so I still have to see whether that is a big deal.
So far, the top'n'tilt seems to save my bacon when I use the iMatch. Without it, nothing lines up quite right and I imagine I'd be back to wrestling implements around, half-an-inch at a time. My implements sit on gravel or on blocks on gravel, not on a level concrete floor, so no doubt that is part of the problem.
There's definitely a learning-curve and coordination issues in play and (he adds sheepishly) I'm no longer young so maybe those are the main issues.
Thanks, Greatlakes37. I got the TNT with the tractor as an option from Deere. Since I was getting the tractor new, I didn't really investigate aftermarket choices. I love it so far but it's very early days yet. I haven't even used it yet for the main reasons I got it (adjusting the box blade angle from the cab and tilting a blade to control runoff on paths and driveways). So far, I've used it mainly to micro-adjust the iMatch for implement hookups and it's been really great for that. It's surgically precise and of course I can stay in the seat to adjust things. The extra switches take a bit of getting used to, but that's to be expected.
Here's a photo of the switch panel. To activate the hydraulics for the TNT, you turn on the switch labelled in Roman numerals II/III, the one with an image of a gear and a book on it! It sounds ridiculous when I put it like that, but the icons actually make perfect sense once you get used to them. Once the switch is activated, the loader joystick controls the TNT instead of the loader.
2020 MACK P164T (A58214)
2020 MACK P164T...
2178 (A58376)
2178 (A58376)
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2007 Splendor 239 Sunstar (A57149)
2007 Splendor 239...
