Oil & Fuel Hard to get to Oil Filter on 1526 Massey Ferguson
/ Hard to get to Oil Filter on 1526 Massey Ferguson #1
radrock
S/O Joplin, Missouri
Massey Ferguson 1526 Hydrostat
So does anybody else have an oil filter that looks like this on their Massey? I have to change the oil for the second time tomorrow. I had a heck of a time getting the filter off the first time. The only tool I had that would fit in this little place was my hand. I have a few oil filter wrenches but you can not use them because of the Hydraulic line in front of the filter. You would think an engineer would figure this out right away and not produce this stuff like this. Hopefully I do not have problems taking it off tomorrow as I only turn them 1/2 turn by hand once they are seated.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #2
Get a new filter, then buy one of those metal end cap filter wrenches. Use an extension and you should get it out. We had the same problem with the 1523. 1635 is a little easier, can use a strap wrench on it.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #3
Looks similar, but a bit worse than my 1540. The first time on an overtightened factory filter, I got on the very end with a large pipe wrench.
It looks like a cheap strap wrench might work on yours.
I have had it off on my 50 hour service. It was a bear. Problem is you can't get any filter wrenches in that little space. I have a web filter wrench and regular wrench. I could get to the filter real easy on my 1215. Everything else is easy to get to. Massey should have made a different Hydraulic tub instead of blocking the filter. I'll let you know how my oil change goes tomorrow haha
Radrock, do you have a pic taken not as close?
Not right now. I'll take one farther away tomorrow and will take the FEL off. It is just easier to work on. I'm going to change the Hydrostat oil and motor oil both. I like that I can open the hood and remove the side panels as well. Most everything is real easy to get to.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #7
An end cap filter wrench will work. Our 1523 was the same way. That is an Iseki design, not MF's fault.
strap wrench won't work. tried that. Hopefully it won't be hard to get this time.
Not for sure but you are probably right. I think the 1523 has the same motor as well. 91 CI?
Well you guys got my curiosity up too much. I just went out to the garage to see if I could spin it off by hand. No problem. Like I said I didn't over tighten it when I changed oil. So as long as I don't get too carried away when putting on the new filter it shouldn't be any problem. No oil leak. Of course I think they are harder to take off when hot anyway. I just have a hard time dealing with the fact they would build it that way.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #11
It had the same engine as the GC, 68.5 ci. Looking at the pic, layout looks the same. Cannot get a strap wrench on it. Had to use end cap. Can use a strap on the 1635 though.
Ok, My 1215 had the same 91 Ci motor in it but was only 17 HP. It really was a good tractor and served me for 14 years. I do like the 1526. I have had it since March and only one problem to speak of. I will have to find a end cap wrench and see if it works OK because sooner or later I'll have a hard time getting that critter off. It has that bracket in front for the side panel as well.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #13
I use a Craftsman Auto Adjustable Universal Oil Filter Wrench (part number 28-205230) on an hard to access oil filter on our '08 Subaru Forester. (Another dumb design. They went to this after havinga oil filter that was accessable and you could change it out in 5 minutes with no problem to one where you have to reach through a donut hole in the hot exhaust manifold after removing a plastic rock shield. DUMB, Dumb Dumb!)You use a 3/8" x 6" or longer extension and a rachet with this device.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #14
Thank you. I will look into that. I have a claw wrench similar to that, but it only works for removal.
Product Page
/ Hard to get to Oil Filter on 1526 Massey Ferguson #15
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=289234"/>
Most auto parts have end cap oil filter wrenches where you use a socket ratchet to loosen the filter. Since filters are different diameters, measure yours and how many facets it has then go shopping. Service centers use an end cap type filter remover. Along time ago I used two phillips screwdriver and drove them into the filter at an angle to twist the filter loose. I now have one of those fancy self adjusting end cap wrenches that will work on any faceted top filter.
/ Hard to get to Oil Filter on 1526 Massey Ferguson #16
I could not use a strap wrench either. Radrock yours looks very close to my tractor.
Here are a few more pictures, One from further away. As you can see, it is a very little filter. I changed the oil, filters, transmission/Hydrostat oil, filter and cleaned the strainer. It was a pretty nice day out today to get it done. Now I am ready for winter.
The oil filter came off by hand with no problem. I loosed it up last night while it was cold. I will have to check and try to find a cap wrench, just in case it is too tight next time. It will even be hard to use one of them. mguitas, I would say your tractor is pretty close to mine. WilliamBros had a 1523 and said it looked like his too. I used a tape measure to give you an idea how close everything is around it.
Everyone have a great week!!
/ Hard to get to Oil Filter on 1526 Massey Ferguson #18
Yupp, that is as tight as our 1523 was. Did you keep the filter? Take it with you to try out an end cap wrench. Do you have a swivel extension? Get one of those too, it will make your life easier.
Thanks for the pics. What did you run for oil?
1635 filters...
First oil change, we cut the tie strap, and adjusted the wiring in front of the filters. I can slip a band wrench between the wires and filter with no problems. Would be kinda awkward if we had a loader though.
And here is the 1523...
It was a tough one, had to use the end cap. Had a hard enough time wiping the filter head off before installing a new filter.
What part number is your filter?? 72201898? That is the filter for the 1523.
Just an Update...
A KD 3253 end cap wrench fil the Luber Finer Filter #LFP8176. I can't remember if it fit the MF filter, but it does fit the luber finer, and the AC filter on my Sportsman. Guessing it will fit though.
http://www.luber-finer.com/catalog/parts-catalog.aspx
http://www.luber-finer.com/catalog/part-detail.aspx?id=000292876&partno=LFP8176
KD 3253 cap wrench.
http://www.oreillyauto.com/site/c/d...T_-1_-1&mc=KDT&mn=KD+Tools&pt=N0066&ppt=C0164
Thanks for the pictures. I will get another oil filter and take it with me to make sure it matches. The motor looks just the same. If you click on my pictures it will make them bigger. Dont know why yours show up bigger on the computer. One difference is that your Hydraulic line curves below the filter where mine cuts right in front of it. That line is the biggest problem. But it wasn't that bad. Thanks for the info on the wrenches. I will check it out later.
George
/ Hard to get to Oil Filter on 1526 Massey Ferguson #20
George
I upload all of my pics in top quality and the original size (largest, not resized.) to my photobucket account, then copy the image link and past it with the text.
I think the end cap will be the best bet, and with a short swivel extension, you can spin it right off with no problems.
MAHINDRA 3650P TRACTOR (A60430)
MAHINDRA 3650P...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2004 CATERPILLAR 320CL EXCAVATOR (A60429)
2004 CATERPILLAR...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
(APPROX.15) 5/8"-4'X8' OSB (A60432)
(APPROX.15)...
