How do I get rid of ticks ???
   / How do I get rid of ticks ??? #21
i have no guinea fowl.. but have plenty of free range chickens.
   / How do I get rid of ticks ??? #22
The Spectracide granules do work, we were covered up so badly here that I found one on the wall inside the kitchen when our house was 3-4 months old. I spread them in the back for about 100' from the house so it wasn't cheap, but it did the job.
   / How do I get rid of ticks ??? #23
Tick Key Home - The Easiest To Use Tick Removal Device On Earth
Dan I was watching a show on the AT ( Appalachian Trail ) and they said in areas there are a ton of ticks because the snakes have been killed, and they normally take care of the mouse part of the ticks lifecycle.
Here is what we use, Pro-Tick Remedy Tick Removal System - Free Shipping at REI.com. The price is outrageous but the tool is work really well.
I don't kill black snakes since I know they like Mickey. Last night I had to get some wood to the house. I often see mice nest in my wood pile but last night when I removed the tarp I found a tree rat nest. When I ran the tractor last weekend, I checked it for my mice nests and instead found twigs which was odd. After I saw the tree rat nest in the wood pile I figured out how the twigs got under the tractor hood. :shocked: :mad:
Later,
Dan
Wow, a lot of good ideas. I did find an article on line about using a concentrate of garlic. pretty expensive, though. We have two dogs and five cats, frontline doesn't work so good on them anymore, either. I wonder if the cats would leave the guinea hens alone ?
   / How do I get rid of ticks ??? #25
I'd worry about the guineas leaving the cats alone!
   / How do I get rid of ticks ??? #26
I have used Permethrin 33% with the Stihl backpack blower/mist sprayer now for 10 years for mosquito control and also tick control over about 3 acres. A 5 liter container of 33% permethrin only takes 2 ounces to 2.5 gallons of water in the sprayer and does the entire 3 acres every two - three weeks. One 5 liter container costs $100 and lasts for 2 years with about 8-10 applications per year.
You should be able to treat along your trail areas once a month and get decent results, but if you have 20-30 acres to cover you can rig up a sprayer on a small tractor or 4 wheeler and spray the trail areas and perimeter of your yard etc..
The permethrin or similar Di-Phen are all about the same efficacy and also treating your outdoor clothes in the washing machine with an ounce added will keep ticks off for 3-4 months with one treatment.
Yes, permethrin is a synthetic chemical originating from the chrysthanenum flower and is not toxic to animals should not be used around bodies of water - and fish etc, but it is very effective for control of bugs and ticks.
   / How do I get rid of ticks ??? #27
wcampbell47 said:
The go to product in my area for mosquitoes is Bifen/IT or bifenthren.
BIFENTHRIN, is some good stuff.
It is the active ingredient in Ortho Home Defense Max.
I've used the indoor spray to control ants, has a very long residual time. Spray it in the corners and around doors and I'm good to go for months.
For outside I use the concentrate and mix up some in my 15 gallon pull behind sprayer, then go for a leisurely cruise around the property using the boom to spray the the yard, the gravel drive around builds everywhere.
I use the hand wand to spray everything else, trees bushes...if it doesn't move it gets sprayed.
I just have to do that when the bug season starts getting into gear and might have to do a followup quicky spray later, depends on the rain.
If its a bug it isn't happy. Seed ticks..gone, fleas...never saw any, ants...what ants. :thumbsup:
   / How do I get rid of ticks ??? #30
I use Home Defense Max in my house and around the foundation about once a year, zero bugs, never thought to spray the yard with it. Might try that instead of Spectracide this year, can't cost any more.
iDrive TDS-2010H...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
Toro z turn (A56859)
2014 Ford Escape Titanium SUV (A59231)
2014 Ford Escape...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
