How do I get rid of ticks ???
   / How do I get rid of ticks ??? #21
i have no guinea fowl.. but have plenty of free range chickens.
   / How do I get rid of ticks ??? #22
The Spectracide granules do work, we were covered up so badly here that I found one on the wall inside the kitchen when our house was 3-4 months old. I spread them in the back for about 100' from the house so it wasn't cheap, but it did the job.
   / How do I get rid of ticks ??? #23
Tick Key Home - The Easiest To Use Tick Removal Device On Earth
Dan I was watching a show on the AT ( Appalachian Trail ) and they said in areas there are a ton of ticks because the snakes have been killed, and they normally take care of the mouse part of the ticks lifecycle.
Here is what we use, Pro-Tick Remedy Tick Removal System - Free Shipping at REI.com. The price is outrageous but the tool is work really well.
I don't kill black snakes since I know they like Mickey. Last night I had to get some wood to the house. I often see mice nest in my wood pile but last night when I removed the tarp I found a tree rat nest. When I ran the tractor last weekend, I checked it for my mice nests and instead found twigs which was odd. After I saw the tree rat nest in the wood pile I figured out how the twigs got under the tractor hood. :shocked: :mad:
Later,
Dan
Wow, a lot of good ideas. I did find an article on line about using a concentrate of garlic. pretty expensive, though. We have two dogs and five cats, frontline doesn't work so good on them anymore, either. I wonder if the cats would leave the guinea hens alone ?
   / How do I get rid of ticks ??? #25
I'd worry about the guineas leaving the cats alone!
   / How do I get rid of ticks ??? #26
I have used Permethrin 33% with the Stihl backpack blower/mist sprayer now for 10 years for mosquito control and also tick control over about 3 acres. A 5 liter container of 33% permethrin only takes 2 ounces to 2.5 gallons of water in the sprayer and does the entire 3 acres every two - three weeks. One 5 liter container costs $100 and lasts for 2 years with about 8-10 applications per year.
You should be able to treat along your trail areas once a month and get decent results, but if you have 20-30 acres to cover you can rig up a sprayer on a small tractor or 4 wheeler and spray the trail areas and perimeter of your yard etc..
The permethrin or similar Di-Phen are all about the same efficacy and also treating your outdoor clothes in the washing machine with an ounce added will keep ticks off for 3-4 months with one treatment.
Yes, permethrin is a synthetic chemical originating from the chrysthanenum flower and is not toxic to animals should not be used around bodies of water - and fish etc, but it is very effective for control of bugs and ticks.
   / How do I get rid of ticks ??? #27
wcampbell47 said:
The go to product in my area for mosquitoes is Bifen/IT or bifenthren.
BIFENTHRIN, is some good stuff.
It is the active ingredient in Ortho Home Defense Max.
I've used the indoor spray to control ants, has a very long residual time. Spray it in the corners and around doors and I'm good to go for months.
For outside I use the concentrate and mix up some in my 15 gallon pull behind sprayer, then go for a leisurely cruise around the property using the boom to spray the the yard, the gravel drive around builds everywhere.
I use the hand wand to spray everything else, trees bushes...if it doesn't move it gets sprayed.
I just have to do that when the bug season starts getting into gear and might have to do a followup quicky spray later, depends on the rain.
If its a bug it isn't happy. Seed ticks..gone, fleas...never saw any, ants...what ants. :thumbsup:
   / How do I get rid of ticks ??? #30
I use Home Defense Max in my house and around the foundation about once a year, zero bugs, never thought to spray the yard with it. Might try that instead of Spectracide this year, can't cost any more.
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2016 Bobcat E85 Midi Excavator (A59228)
2016 Bobcat E85...
CAT930K (A58214)
CAT930K (A58214)
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
