Kubota BX22 Transmission Case Damage
   / Kubota BX22 Transmission Case Damage #31
How did all this play out? Any sort of a partially happy ending?
It will cost over $3,000. It's still in the shop and the owner never returned my phone call.
   / Kubota BX22 Transmission Case Damage #33
No phones in Texas???
Not getting answers or a simple return call doesn't inspire confidence.
   / Kubota BX22 Transmission Case Damage #34
I'd use a different dealer. Your a paying customer. They have the privilege to serve you and your tractor, not the right. Another dealer may also get something from the regional rep for you.
Good luck and keep us posted.
   / Kubota BX22 Transmission Case Damage #35
what did you find , mine quit pulling forward and oil leak next to frame where I cannot see. How does transmission come out
   / Kubota BX22 Transmission Case Damage #36
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=289364"/>
That looks more like a bad crash than someone working on a tractor.
   / Kubota BX22 Transmission Case Damage #37
   / Kubota BX22 Transmission Case Damage #38
Funny I ran into this post today, Here is what happened to my BX2350. Couple of weeks ago I had similar crack in the same location as this one, used JB weld, change the hydraulic fluid (or what left of it), filter clean screen…etc, no leak anymore. Couple of week later while mowing the grass I smelled a strong hydraulic fluid odder stopped the tractor and looked under and found the transmission case is two pieces.
So biggest mistake was to JW welding it and ignored the fact that the damage seem to come from the inside. That was very dumb.
Taking it to the dealer was out of the question, because I was expecting what happened with Genemcvay, at least with the cost not the way they dismantled the tractor this is really outrageous.
The main problem in my opinion was the damage happened in the differential, looking at the part diagram and found that I should start with the differential replaces what is broken, weld the case and of course hope nothing else broke inside. However the dealer will not do that, the dealer will replace the transmission case and that is a big job and required a mechanic with a very good skills obviously the dealer at Fort Smith doesn’t have.
The tractor has about 700 hours on it, couple of hundreds hour back the diff lock stopped working, I ignored that (who want a diff lock any way), not as dump like rushing to the JB weld thing but still dumb. I think that is when the problem started.
So it seem that something broke in the diff lock, jammed between the gears and the case and broke it.
Some googling today when I found this post and the ones below and start to think more and more than I am right.
http://www.tractorbynet.com/forums/kubota-owning-operating/174040-bx-24-transmission-failure-3.html
http://www.tractorbynet.com/forums/kubota-owning-operating/227085-bx24-diff-lock-disaster-how-3.html
http://www.tractorbynet.com/forums/kubota-owning-operating/174040-bx-24-transmission-failure-4.html
Any way I just started taking it apart yesterday and will see how things will progress.
   / Kubota BX22 Transmission Case Damage #39
This is awfully familiar... I'm in the process of putting my JD 2210 back together, my differential lost three teeth off the spider gears but nothing more. One tooth tried to escape out through the bottom of the transmission, if all 3 had ended up by the sump screen I would have never known anything was broken.
I went through a similar approach with the JB weld etc... I honestly thought I had hit something causing the initial leak (dent on the filter etc..), but when it started leaking again I knew the damage was from the inside. There isn't much clearance between the ring gear and the case, one of the teeth caught between the ring gear and case, it's a small hole and nothing stopped working.
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
