KWentling
Veteran Member
- Joined
- Jun 22, 2002
- Messages
- 1,162
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
Can you tell I'm not happy with Kubota the company and the Kubota dealer in Fort Smith? Oh by the way, because they tore the transmission apart instead of looking inside with a bore scope, I own them $450 already.[/QUOTE]
Having turned some wrenches, and used a bore scope a few times, it's going to be impossible to determine the extent of the damage looking through that hole. A tear down is the only way to be accurate. I wonder too if it wasn't the diff lock going between a gear and the bottom of the case. I have a BX22 also and am very careful to make sure a wheel is not spinning when I engage it. As far as the case goes, if the damage is only the hole punched through, that can be welded. Did they tell you what happened? What's broken internally? This is something I would fix myself on a tractor way out of warranty, but not everyone has that option. Sorry for your troubles. I think you need to be calm and reasonable when dealing with this. $450 to this point doesn't seem out of line to me.
Kim
Kim
