My wife's a#% isn't big enough.
   / My wife's a#% isn't big enough. #1
ka41
Louisiana
2009 L5240HST
I guess that's a good thing. I have a 09 L5240 and I've had a couple of situations when I needed her help while I was trying to attach and implement or load something in the back of the truck. She hops up on it, presses the pedal and it dies. I've tried moving the seat all the way forward and it still dies. She only weighs 105 lbs so I guessing its the safety switch on the seat? Has anyone else ran it to this problem? Its not worth her gaining weight just so she can move the tractor around for me.
   / My wife's a#% isn't big enough. #2
That would be my first guess. Cant think of anything else it could be if it works fine when your on it. On another note....I would use this as an opportunity to earn some "brownie points" with the wife. I think I would have to say to her "Well honey, this tractor aint used to a beautiful bodied person sittin on it....its more used to my big Butt bouncing on it which has probably broken something. This tractor just cant handle a sexy woman being on it...I'm gonna have to get it fixed":D Looks to me like you have two easy fixes here! not a bad situation to be in...consider yourself a lucky man !:thumbsup:
   / My wife's a#% isn't big enough. #3
Get a front mounted weight and sit it on the seat did that for my wife when I let her out of the kitchen.
   / My wife's a#% isn't big enough. #4
I had this exact same problem, though would only cut out if moving around some. If it's because of the same reason I had, and suspect yours is, she just doesn't have quite enough weight to fully depress the seat down and activate the seat switch. You can verify by adding just a bit of weight by pressing on the seat back with your hand while she's sitting there.
Here's what I did. My wife uses these little bumper things all the time on the bottom of vases and other stuff to protect furniture.
I tried a thicker one first, but then it kept the switch pressed all the time and I didn't want that. I ended up using the very thinnest one (about 1/16 inch thick) and it worked great. If the seat is unoccupied the seat safety switch still works as it should. But now it no longer cuts out. I stuck it on the seat bottom right where the switch will hit the seat bottom (when the seat presses down from sitting on the seat.)
The seat is lifted up vertically here. You can see the little bumper thing stuck on the seat where the switch hits.
   / My wife's a#% isn't big enough. #5
You should be able to just adjust the spring for her weight and slide the seat forward. Same thing happens with my 11 year old son. He is less than 100 lbs.
   / My wife's a#% isn't big enough. #6
Maybe a second (auxilliary) wife? Can you replace or change the position of the seat support springs? Please don't circumvent the seat safety switch. Wives with that size are extremely hard to find and worth their weight in gold. Really !
Thanks everyone for your suggestions. I will try the spring adjustment first and if that doesn't work I'll give the bumper thing a try.
   / My wife's a#% isn't big enough. #8
Kubote Grand L series have 2 safety switches. By flipping the seat (no operator on the tractor), you can use the PTO. That switch is visible under the seat and shut down the engin if the PTO is on and the oprtator leaves the seat. The other switch is inside the seat. It detects the operator presence and allow to move the tractor. I had a problem with that switch on my L3540 HST. When mowing the field, the motor kept bogging down when I hit bumps. It was not a question of weight, beleive me (I weight probably more then twice ka41's wife). I tried to disassemble the seat to find the switch but I could'nt to it with the tools I had with me. I submitted the problem to my Kubota dealer (tractor was no longer under warranty) and he suggested to unplug the connector for that switch and put a jumper in it. I did just that but I regret it. Lately, the motor was running and I stood on the side of the tractor. I mistakenly touch the speed lever (the one used to maintain steady speed in the field) and the tractor began to move. I had time to place it back in the neutral position but I could have found myself in trouble. The switch I bypassed would have prevent it by shutting the motor down. Conclusion, ka41's seat switch might be broken or will soon break and he will face the same issue I hade with mine: Putting a low cost bypass or going through the trouble and the $$$ to repair it.
   / My wife's a#% isn't big enough. #9
There is no spring adjustment. Might shimmy it up with some tape and a piece of plastic/cardboard on the OPC switch arm for it to make a bit earlier and easier.
JC,
   / My wife's a#% isn't big enough. #10
I had the same issue. It is a pain in the neck poor design. The switch is inside the seat.
I had the dealer replace the seat under warranty. It didn't help.
The only thing you can do is jumper it, but that leads to other issues and just isn't safe.
It stinks that they make a nice tractor and then there are some things that just don't make sense.
3ft Rotary Mower (A47809)
3ft Rotary Mower...
2008 Ford F-250 4x4 Super Duty Crew Cab Pickup Truck (A46684)
2008 Ford F-250...
2005 Pitts LB35-33 Lowboy (A47371)
2005 Pitts LB35-33...
1025 Gallon Tank (A47809)
1025 Gallon Tank...
2013 Chevrolet Cruze LS Sedan (A46684)
2013 Chevrolet...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A46884)
Kubota 24in Quick...
