Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #11
I built a narrow (6") ditch bucket for my 580B several years ago, have clay soil, spent as much time dumping as filling :=(
If I ever need that function again, I'll either rent a trencher or build one of these (don't remember where I got the pic, I do a LOT of "researching", spelled T-H-E-F-T :=)
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #12
You bucket looks like a cribbing bucket. We use them to crip out the ballast between crossties on the railroad. They do pretty good for digging narrow trenches too.
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #13
I found this somewhere.
  • selfcleaningbackhoebucket.pdf
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #14
Thanks fisherridge. Without the drawing was struggling with the design concept.
Hi,
That is the basically the thing I did except I welded the ends inside the bucket next to the upper edge. That way there is nothing to remove off the machine when you change buckets. I did not tie the two chains together with a cross chain, but made them quite loose, so they could flop around.
Joe
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #16
Hi,
Joe
So when you dump the bucket, the chains dont actually pull tight then??
I would think with them attached to the dipper like in the pic, that having them draw up tight when the bucket is dumped, would be more effective?
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #17
what no hand ties lol rail roader myself
   / Solution for a Clay Packed Twelve(12) Inch Backhoe Bucket #18
Search google for "Mythbusters cement truck":D
2008 Honda CR-V SUV (A55853)
2008 Honda CR-V...
2022 John Deere 5075E MFWD Tractor (A53485)
2022 John Deere...
CURT MANUFACTRING 1280# SQUARE JACK (A57192)
CURT MANUFACTRING...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A57192)
UNUSED INDUSTRIAS...
Forestry Truck Grapple and Frame (A55852)
Forestry Truck...
