Ballast Box Blade
   / Ballast Box Blade
Nice set up. :thumbsup:
Do you know what the original weight for the box blade is?
I'm not positive....but my guess is about 300 lbs. I have two more weights to add.....so I can get the total weight up to about 900 lbs. (and I do have a HD "basket" that can go in place of the receiver hitch. I guess I could use that for more weight...but I likely will haul some tools in it. I think it would add about 100 lbs empty.
   / Ballast Box Blade #12
I had an old chunk of 1/4x 2 x 2" angle iron....about 18" long. I simply bought a 2" reciever at the farm store and welded it to this angle. Then I gusseted it to the inside to prevent bending. Drilled holes and bolted it on. Ir's kinda medium duty.....but it seems to do everything I need with it. I had the 6" drop hitch...and that seems to get me under most trailers pretty well.
Thank you so much for the info. :thumbsup:
   / Ballast Box Blade #13
youll find that if you use the box heavly, and fill it up, that youll push the weights out. (ask me how i know)
instead hang the weights outside the box to reduce the amount of area the dirt can push up against.
I put a 5' lenght of railroad rail on the back of mine. left about a 2" gap between it and the back wall so dirt could still spill out and i wouldnt pack it solid.
the RR rail weighs more than my BB. Id say my BB is only 200-250lbs while the rail is a good 300+
for the record, adding the weight made my box blade act ENTIRELY different. (for the better)
   / Ballast Box Blade #14
Love the box blade. Searching Craigslist for suitcase weights. Awesome idea.
   / Ballast Box Blade #15
Adding the imatch also extends the box blade back about 6" which acts as even more counter weight. For me it's the perfect ballast!
   / Ballast Box Blade #16
makes a huge difference having all that weight. we cut prototype muffler cores at work on our tube-laser. i saved up two 5 gallon buckets of the 3-4mm x 1mm thick 409 stainless slugs from cutting the perforated patterns and packed them into a 2.5" x 5" x 3/8" wall piece of scrap tubing 6ft long and welded that to the back of my box blade. digs good now :)
   / Ballast Box Blade #17
Has anyone attached a Ballast Box to a Box Blade for added weight? Would love to see a design or better yet a picture if one is available.
   / Ballast Box Blade #18
I agree! It would utilize the existing weight of the box blade in addition to providing a useful tool.
Edit: I realized after writing the above that this is what the entire discussion is about.:eek:
   / Ballast Box Blade #19
Looks good foggy, I now have 10 suit case weights on my BB. Only 6 in the picture, I also bolted two 60 lb pieces of one inch steel plate to the back.
   / Ballast Box Blade #20
I have a regular Ballast Box and I've been thinking about attaching it somehow to my Box Blade to add weight. I don't have separate weights so just trying to use what I do have.
2018 Dodge Charger Sedan (A55758)
2018 Dodge Charger...
28013 (A50322)
28013 (A50322)
19088 (A55758)
19088 (A55758)
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
2009 Wacker-Neusan Hand Packer (A53316)
2009 Wacker-Neusan...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
