When do you use the block heater on the tractor
   / When do you use the block heater on the tractor #51
A multi viscosity oil like, lets say 10w30, would be at the equivalent of a 10 weight oil at 0c and a 30 weight at 100c... give or take.
Since a 10 weight oil would flow better than a 30 weight would the use of an oil heater actually thicken the oil up?
Well, let's test that one. Take a 10w30 and put it in a freezer. Take another quart of 10w30 and heat it at around 200F in your oven and see which pours easier or if the warmer one is thicker. Might surprise you.
Sure, a 10w30 will flow better at 0F than a straight 30, but you will be hard pressed to find a 10w30 that flows thicker at room temp than a 10w30 at 0F. In a multi-grade oil, the oil is NOT the thickness of the first number and then thickens to the weight of the second number. The first number before the "w" is the winter flow rating, not the weight of the oil. A 10w30 or a straight 30 are both 30 weights. It is just that with more refining, and viscosity improvers, the multi-grade flows better at a lower temp. Hence, it will flow in winter like a 10w, but it is in fact a 30w.
It is a common fallacy that the first number in a multigrade oil is the weight of the oil at cold temps and the second number is the weight of the oil at operating temps. The first number only represents the way it will flow in cold temps, not the weight. Check with the Society of Automotive Engineers (SAE), and they will confirm this.
   / When do you use the block heater on the tractor #52
The 300W magnetic heaters will warm the oil enough in the oil pan to assist start up lubrication if........ Plugged in for hours and the machine is parked out of the wind.
   / When do you use the block heater on the tractor #53
I bought 2 of them once and plugged in for 12 hours in -30c they made no difference at all .
   / When do you use the block heater on the tractor #54
I stuck one on the oil pan of the 1640 , parked in the shed at 10F. Oil pan felt warm compared to the rest of the tractor. Probably 50-60F. Certainly enough to assist cold start lubrication. at -40F the improvement in flow would be worthwhile. Even if the oil temp was raised only from -40F to 20F.
As far as using magnetic oil pan heaters as an attempt to heat the entire engine instead of using a coolant heater . Certainly a lost cause.
John Deere 4600 (A53317)
John Deere 4600...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
3Pt Aerway (A59814)
3Pt Aerway (A59814)
