Penetrating Oils....best and home made...
   / Penetrating Oils....best and home made... #31
Any type of ATF. It's just that ATF is the thinnest oil most people have handy.
   / Penetrating Oils....best and home made... #32
A bit off topic but an old time method was to use heat and wax. Heat a rusted nut and the melted wax would get drawn into the threads and break them loose.
   / Penetrating Oils....best and home made... #33
Never heard of that of even tried it on nuts/bolts. BUT, that is a common method on removing pipe plugs from engine blocks. Like the three oil galley plugs above the cam bearings at the rear of the block. And it does work surprisingly well on those pipe fittings. Because the nature of pipe fittings forming a seal, other penetrants dont work very well.
   / Penetrating Oils....best and home made... #34
Most of the gunsmith supply places sell Kroil. Try Brownells. It can also be ordered direct from Kanolabs. It is expensive but the oil, not the aerosol, can be used in a oil squirt bottle and just a drop or two will work and the can will last a long time, a gallon will last a lifetime at home.
   / Penetrating Oils....best and home made... #35
He's not kidding about the one drop. I think that is all I have ever used on something stuck. If you buy a gallon, make a note in your will.
   / Penetrating Oils....best and home made... #36
Makes sense. About 30-40 years ago I hears I heard that Ford Type F ATF was basically a 10 weight oil with antifoaming additives and red dye. The new stuff (Dex Vi and others) appears even lighter now (but same red dye).
DEWFPO
   / Penetrating Oils....best and home made... #37
I have a can of what you guys call Kroil. Its an orange can and the name on the can is actually AERO-KROIL. I got the can when i was a machinist back in the day. Have never seen it since on any store shelf. Yes this stuff is the king of all penetrating oils. Spray something at night come back in the morning and its like magic. I did have to use heat with it one time on the shock bolt that was frozen to the bushing on the shock. I didn't want to wait over night so i used heat,spray, and an 8 lb sledge but it worked.:cool2:
   / Penetrating Oils....best and home made... #38
I have been using PB penetrating oil with pretty good success and forgot about Kroil until reading this thread. I'm going to keep my eye open for it and pick some up when I see it. Can you get it at Home Depot or Lowes?
I don't think I'm going to try the mixing it myself approach. Looks like there might be to many issues to deal with if I get it wrong. To me, it's not worth the effort to mess with it.
I love WD40 for cleaning. It gets nasty stuff off my hands better then anything else, and it's also great for getting glue off of glass. Really a great cleaner, but it leaves an oily film, so it has to be cleaned up with windex after using it to remove glues.
Eddie
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Mower King Brush Cutter (A53317)
Mower King Brush...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
