How / Who / What can bend this 3/8 inch plate steel bracket back to shape?
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #1
Botabill
Ontario
Here are photos of a bent bracket that attaches the hydraulic augur to the dipper on my excavator. The o-ring that held the pin in through the bracket broke and one side of the bracket is bent. I've tried putting the one side of the bracket against an immovable object (a rock) and beat the bent bracket 6 pound sledge hammer. Great exercise but there was no movement. Does anyone have any suggestions? I considered heat but this may soften the metal to the point of making it too weak to do the job it was intended for. If anyone knows how to solve this challenge I think tractor by net members will. Thanks!
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #2
Around here any welding or equipment shop can straighten that out.
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #3
i agree a machine / weld shop could do it.. however.. I think a 50t bottle jack and log chain will do it too...
I'd have few qualms about heating a broken part if I needed to.. it's already broke.. :)
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #4
That's not a bend, just a little tweak. Heat and beat will fix it.
Or put in a spacer, heat it up, and use a big C-clamp.
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #5
Machine shop here has a 100T press..........he'd charge me $20 and it would take him 10 minutes.
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #6
Another excavator with a thumb, put a spacer between, and pinch it with a bucket and thumb
Sent from my iPad using TractorByNet
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #7
what.. nobody owns a bottle jack anymore? :)
the stuff i've bent with a bottle jack and chain is pretty impressive.. including straightening bowed radius rods and trailer front frames..
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #8
Chuck Norris could.
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #9
Chuck Norris could.
it'd bend for sure.. but the sweat from his hands and arms might disolve the metal first.. :)
reminds me. I heard chuck was bit by a cobra a while back. after 3 days of pain, the cobra finally died.. :)
   / How / Who / What can bend this 3/8 inch plate steel bracket back to shape? #10
Get a good grip on the end of the bent "ear" with a pair of vice grips.
Heat the bend radius with a torch until dull cherry red.
Apply firm, controlled force on vice grip handle to straighten the ear.
If you can weld a pipe onto the top of the vice grip as a cheater, you'll gain some leverage and control.
Adjust where the torch is heating the bend as it starts to straighten, so you continue to unbend the parts that are still bent and don't bend the parts you just straightened.
Take your time.
Stop when it looks straight and allow it to cool slowly.
This is one of the most enjoyable jobs I know of.
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
KENWORTH SERVICE TRUCK (A51406)
KENWORTH SERVICE...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53473)
2-Row Peanut...
