Wheel Spacers - L3400 HST
   / Wheel Spacers - L3400 HST #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I have a Kubota L3400 HST w/FEL 4WD, R4 tires. It seems a little unstable on slopes. Actually - more than a little! So, I was thinking about adding 2" spacers on back. Anyone had experience with this and added spacers? And drawbacks to that?
Any advice would be appreciated.
Jim
   / Wheel Spacers - L3400 HST #2
The only thing I see is it will add more stress on the outer axle bearing because you are extending the axle. Someone had some pictures of wheel spacers a few months back. Maybe they will come along.
   / Wheel Spacers - L3400 HST #3
Do you have loaded tires? If not that will make your L3400 much more stable on slopes. And proper ballast on the 3pt when using your loader will help too. I don't have my L3400 any more, but I live in Branson, Mo. and we have two kinds of ground here, UP and DOWN. :) When I loaded the tires, I noticed a positive difference on side hilling when I mowed the back yard. And it is pretty steep. With my ballast barrel and the loaded tires, I felt pretty safe with the L3400. When it was delivered new it was no fun to use around here.
James K0UA
   / Wheel Spacers - L3400 HST #4
I just put 4" spacers on the rears of my BX25. They've made a big difference on our very hilly property. I wish I'd done it several years (and many close calls) ago!
   / Wheel Spacers - L3400 HST #5
Does it not have adjustable rims? Or is it a one piece rim and center?
Yes, I do have loaded rear tires. The R4 rims, as K0ua said, are not adjustable.
Like your Branson property, mine's either updhill or downill :)
   / Wheel Spacers - L3400 HST #8
Well if you are still having trouble, then the spacers may be the answer..Several of the guys here have put 2 inch spacers on the L3400 for chain clearance, without any adverse results. I am sure that would also make a positive difference in your feeling of safety.
James K0UA
   / Wheel Spacers - L3400 HST #9
I installed the Kubota spacers on my L3400 for chain spacing. Only gives you about 1+1/8 each side. The dealer ordered me the Kubota "kit" which was just the spacers but then there is a "kit" of longer studs for the kit. Not a small dealership but it took them a while to figure it out. About $300 in all. I'd try to find spacers somewheres else if I had to do it again.
Worst part was removing the wheel nuts. Kubota Loctited the nuts. Could'nt break them loose with a 4' crowbar extension. Needed an impact wrench in the end. Old studs came out surprisingly easy. If your wheels are loaded you'll need a dolly or something to pull the wheel out, install the spacers, push the wheel back and get it aligned right. Whole thing took me a couple of hours with some help.
Thanks for that info outoftractluck. I am going ahead with the wheel spacer project. I've order a set of 2" spacers from Bro-Tek, which also was about $300. Bro-Tek spacers simply look a lot more professionally made than any others that I've seen on the internet.
I am taking a shortcut though - and that is having my local Kubota dealer install them for me. I don't think I have enough grunt to handle a 500# tire, even with a dolly. Cost for that is only about $50 though.
   / Wheel Spacers - L3400 HST #11
Too bad you don't have the adjustable rims. Others mentioned the extra stress on the bearings from spacers. It's there, but not a real issue (with Kubota's anyway) as the same rear is used with rims that are adjustable further out than your spacers.
I've moved many a loaded tire around. Never EVER never would I use a dolly. Do it on smooth cement or dead flat grass. You can easily walk the tire around. Walk one out, roll it aside to lean against a wall or the tractor front, install the spacer, roll it back, walk it in place. You can rotate the axle or even pull up and spin the loaded tire pretty easy. The only real issue is mental, you have to know when to abandon the tire and let it fall over , 'cuz even a superhero would be seriously injured letting one fall on him! That's just so you know.
The $50 isn't a bad price at all, but should you ever need to do it yourself, it's a 30-40 minute job for me to pull both filled rears off and swap sides (needed to adjust rims to centers for some widths). Never dropped one yet (knocking wood like mad)...
Right John_Bud, for me a dolly would make a heavy tire unstable. The R4 should just about stand up by itself.
I need to take the little Kubota in for a checkup anyway, so I'd just as soon that some young mechanic take care of this while it's there. The dealer has the right tools, i.e. a tire dolly and a big impact wrench. ...yeah, I've handled some heavy stuff in my time, like pulling hydramatic transmissions and re-installing them without a jack. I suspect that if I did let a tire fall over, I'd get it up and back on somehow.
Some of us don't age so kindly though. Strength's not what it used to be. After a heart attack & stroke in recent years, I don't have the strength that I used to have. That, and perhaps, getting to be 72 might have something to do with it :)
You info is, however, appreciated. If I change my mind about doing it myself, I'll keep the pointers in mind.
   / Wheel Spacers - L3400 HST #13
John_Bud: Thanks fo the advice. You must have some muscles! I guess I was just dumb enough to use the advice others suggested in this forum and the dealer who said to try and slide it out sideways or I'd have a real problem getting it to line up again. For me the dolly worked like a charm. The wheel sat right in there. Anyway, you probably have a lot more experience with this stuff than me but if I had to do it again I'd NEVER do it any other way. Kinda glad I changed the spacers before I read your advice.
Well - I got the 2" spacers on. Dealer only charged me ~$40; money well spent for me. Here's a pix before and after.
   / Wheel Spacers - L3400 HST #16
Money well spent indeed. Good deal! My dealer wants $100 just to pick up and deliver not including any work.
   / Wheel Spacers - L3400 HST #17
I have an L3400 with R1s on the rear and adjustable rims. After nearly tipping it over, I set the wheel spacing out to the maximum with only added about 5" increased width but made a world of difference. My rear wheels were filled all through the tippy incident and widening the rears.
I don't think the HST's with R4s had adjustable rims as an option. That would be nice though. My wheels are also filled but even with attachments like a 500# BB, I've had it in tipping mode :-( That's NOT a fun feeling. Hopefully the extra 4" will be better.
BTW sdkubota, the $40 the dealer charged didn't include pickup and delivery. I took care of that. BUT, before I got my trailer the dealer near Houston - in Webster, TX (name of L-D, M) charged $4.00 per mile, round trip. Absurd, but that was right in line with the rest of their labor charges. City Slicker rates.
Now we've moved to Warm Springs, GA. The dealer in nearby Waverly Hall, GA is a good ole' country boy. Charges reasonable rates, good service, and does what he says he did. Can't ask for more than that.
   / Wheel Spacers - L3400 HST #19
That 4" will make a good deference. I have loaded R-1s set out max and my L3800 is very stable.
Rear wheel weights would help put more weight on the ground, if needed.
   / Wheel Spacers - L3400 HST #20
You could probably install the spacers yourself. I was nerovous about handling the fluid filled tires by myself but wasn't a big issue. I kept them upright at all times and carefully moved them by rolling.
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2017 Make...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
CATERPILLAR 416C BACKHOE (A60429)
CATERPILLAR 416C...
