Would you buy a Roto tiller with Forward and Reverse rotation?
   / Would you buy a Roto tiller with Forward and Reverse rotation? #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
We have the Tarter Tillers in the 48" at $1595, The 60" at $1695 and the 72" at $1795 + shipping. These tillers feature, reversible tine rotation, gear drive, slip clutch drive line, Tine scroll diameter approx 16", From tip of tine to center driveshaft is 7 inches, In new ground 4" cutting depth on first pass and 6-7" on second pass, Colors subject to change, depending on availability. Prices subject to change without prior notice. Below is a picture of the tiller and another picture showing the step by step directions for reversing tine rotation. Tillers will be shipped in forward rotation configuration. Ken Sweet
   / Would you buy a Roto tiller with Forward and Reverse rotation? #2
where are these made, just out of curiosity? and what are the weights?
4 Ft--591 Lb.
5 Ft--638 Lb.
6 Ft--718 Lb.
About Tarter
Tarter Farm and Ranch Equipment is 66 year-old company still privately owned and operated by the Tarter family and currently operated by the fourth generation of Tarters. As the largest farm and ranch equipment manufacturer in the nation, they manufacture over 1000 skus across 10 product categories, and ship product to dealers in all 50 states and Canada.
Ken Sweet
   / Would you buy a Roto tiller with Forward and Reverse rotation? #5
If I was in the market for one, I'd definitely want the reversing feature. I don't see it as an actual tilling benefit, but reverse sure makes cleaning clogged tines easier.
//greg//
   / Would you buy a Roto tiller with Forward and Reverse rotation? #6
I kept looking at the picture trying to see the transmission to change rotation with. Then realized you had to flip the gear box to change rotation. Since I have a kingcutter, which is a very good tiller by the way, I am going to go look and see if flipping the gear box will change the rotation on it.
   / Would you buy a Roto tiller with Forward and Reverse rotation? #7
If iread the instructions correctly to changerotation direction you have to remove the gear box and then switch the tines. How long would this process take one the bolts are covered with dirt, mud, vines, etc.
Great idea but makes me wonder about the true value in real life conditions.
Roy
Roy
Most buyers would set it up for forward or reverse, when they buy it and leave it that way forever or until a different field condition arises. They are not designed to change out ever other day, just to have as a option. Ken Sweet
   / Would you buy a Roto tiller with Forward and Reverse rotation? #9
Ah, well then that model would be useless to me. I borrowed one a while back that could be reversed "on the fly" so to speak. I thought that's what we were dealing with here - my bad
//greg//
//greg//
Tines sharpened on both sides? Looks like the tine sweep angle would be correct one way and not the other. Do you remember the brand you were using? Ken Sweet
   / Would you buy a Roto tiller with Forward and Reverse rotation? #11
Maybe you should have painted it green Ken. Then 90% of the people on these forums would have thought it was the best. LOL.
How about yellow? The next ones will be a different color for sure. Ken Sweet
   / Would you buy a Roto tiller with Forward and Reverse rotation? #13
And add yellow stickers!! :)
I will not own a forward rotation tiller. We converted ours to reverse, best money spent. Oou soils are clay based, so the reverse does a better job.
   / Would you buy a Roto tiller with Forward and Reverse rotation? #14
No sorry, it was a borrowed machine. I cannot say with confidence that the tines were sharpened on both sides, but I don't see why not. Nevertheless, I didn't till in both directions. I just used reverse to clean accumulation off the tines.
//greg//
   / Would you buy a Roto tiller with Forward and Reverse rotation? #15
Far as me personally no I would only buy a forward or reverse rotation tiller and leave it at that.
I happen to like forward rotation and I cant see myself ever needing a dual purpose tiller or me taking the time to switch one around and back etc but thats me.
It may have added value as far as resale but that still wouldn't influence me to buy one unless it was only a matter of shifting a gear shift lever then maybe just maybe.
I am lazy and all I want to do is hook up something go work come back un-hook go get something else and so on. :D my .002
   / Would you buy a Roto tiller with Forward and Reverse rotation? #16
I will not own a forward rotation tiller. We converted ours to reverse, best money spent. Oou soils are clay based, so the forward does a better job.
I'm confused. You don't like forward rotation so you changed yours to reverse but forward does better in your soil. ??????
   / Would you buy a Roto tiller with Forward and Reverse rotation? #17
In my limited experience having tried both in my clay/rock soils I chose forward. It kicks the rocks and clay clumps rearward so I can pick up before the next pass. The reverse rotation kept throwing rocks,dust towards the rear of my tractor, only to get hit again - I got tired of stopping to kick rocks out of the way.
Just my 02 on what worked for me.
   / Would you buy a Roto tiller with Forward and Reverse rotation? #18
Looks like a good tiller and sure makes for a good selling point for a guy that doesn't know what he wants.
   / Would you buy a Roto tiller with Forward and Reverse rotation? #19
A typo at work, fixed it. Reverse does a better job. After having both, no more forward for me.
   / Would you buy a Roto tiller with Forward and Reverse rotation? #20
wouldn't it be better to use a dual-input-shaft gearbox, then you could reversed by putting the shaft on the other end of the gearbox, then moving the 3pt frame and the rear "flap" to the opposite side? Seems easier than switching all of the tines around.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
