yanmar ym 1500 battery?
   / yanmar ym 1500 battery? #11
for those in the US there is codes that you can use to get $30 off a battery from Advanceaoutoparts.com This will make their batteries the cheapest around.
o dont get many bargins like that here
   / yanmar ym 1500 battery? #13
The last 3-4 batteries i have bought from them i have used this online then picked them up in the store. That $100 battery is now $70! ;)
   / yanmar ym 1500 battery? #14
FYI, my 2012 model Yanmar came equipped with a 540cca battery to turn over a 4cyl 4tnv88 engine.
Part/Model# 526RMF
Group Size 26R
   / yanmar ym 1500 battery? #15
Does your 2012 model have compression release?
   / yanmar ym 1500 battery? #17
No compression release that I can find. Just warm the glow plugs and turn it over. I did some research and conclude it must come with a gear-reduction starter, that I know will use less amps then a conventional starter. Maybe you can refit the older engines with a gear-reduction starter, I've done it before with an old surplus military truck.
The compression ratio I found on the 4tnv88 spec sheet is 19.1
   / yanmar ym 1500 battery? #18
My curiosity has been touched. I have several manuals and one for a ym276 engine which has a compresson ratio of 20:1. Suppose to have 497-569 compression psi @ 300rpm.
Read a couple of internet conversions on compression ratio to compression psi to use 14.7 as multiplier. Evidently that doesn't work with these Yanmars. 20 X 14.7 = 294. Can you gurus tell us how to convert ratio to psi?
I'd bet a dollar to a donut that 4tnv88 has a pretty high compression psi also.
   / yanmar ym 1500 battery? #19
Hey Winston, I'm actually flying down your way tomorrow, I'm spending Christmas at my brother's in Killeen, TX.
I'm not a diesel expert but I'll ponder your question on the flight down. The only compression figure I can find for the 4tnv88 is 93.8 PSI for "BMEP, Net Power." I'm using martindiesel.com for the spec sheet. http://www.martindiesel.com/products/Engines/4TNV88 SPECIFICATION SHEET.pdf
Also, I'm wondering if there have been some compression design changes over the years due to EPA requirements so these diesels burn a little cleaner. I know that's what killed the Army's LD-465 multifuel engine which has a 22:1 compression ratio.
   / yanmar ym 1500 battery? #20
... Maybe you can refit the older engines with a gear-reduction starter ...
I put a gear reduction starter spec'd for a later and larger Deere/Yanmar on my YM240 (YM2000). I recommend this. It now cranks frantically fast and fires instantly regardless of starting technique. The more powerful starter was a perfect clone replacement. I only had to add a few inches to the wire that comes down from the key switch.
Cost me $100 (new, no exchange) via ebay.
Here's a post I made back in January with a photo of both starters. I described the high-output starter earlier in that thread, post #26.
As I noted there - this could also be a suitable remedy if compression seems too low for reliable starting. I wouldn't be surprised if this high-output starter, designed for a four cylinder engine, spins this little twin 50% faster than its native starter did when new. As I said, highly recommended.
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
