Hydraulic Fittings Confusion
/ Hydraulic Fittings Confusion #1
unixkid
turnersville, NJ
kubota
I found some information at surplus center which now has me confused regarding the fittings I need to use for my log splitter project. So here are some questions about hydraulic fittings.
1. whats the difference between NPT & NPTF ?
2. the surplus center information said the best connection should be with SAE o-ring not with NPT.
3. can you get cylinders and valves with SAE o-ring ports ? I only see them with NPT or NPTF ports.
4. does everyone just convert at the connector NPT to SAE and then back again ? this doesn't make sense.
5. what do you guys do ?
I can go on and on with the stupid questions in my novice lay person knowledge of the subject matter so I will stop as I think you all understand my confusion by now. :confused:
Please help.
Thanks,
-unixkid
/ Hydraulic Fittings Confusion #2
Here's a BIG start -
http://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
NPT is National Pipe Tapered - NPTF is National Pipe Tapered Fuel - compatible enough to interchange, but needs sealant or it will leak.
SAE O-ring, aka ORB, are much better than NPT - with a 90 deg. fitting, you can point it whatever direction you want and THEN tighten the lock nut which pushes against a flat washer which pushes against the O-ring which makes a leak proof seal pointed the direction you need it. Try that with NPT, it'll almost never point where you want it and seal.
Some cylinders come with SAE/ORB fittings, some with BSPP (British Standard Parallel Pipe), some with NPT, some may even come with JIC 37 deg. fittings. Last two I bought, one was BSPP with an included adapter to ORB, other was NPTF and I'll add NPTF to JIC straights and JIC male/female elbows so I can point them where I need them.
Same place as the above thread chart DiscountHydraulicHose.com also has tubing compression fittings that will adapt to JIC, etc - check out their site, there's lots of pix but not a lot of "schooling" - Surplus Center's tech section seems to have more of that.
Also -
Technical Frequently Asked Questions
http://www.derijcke.com/dl/manual.pdf
http://www.phtruck.com/download/training/trainingbasichydraulics.pdf
Those should get you started - I've spent about two days just looking thru discount's site and sussing out what things were, and still messed up my parts order til JJ filled me in on WHY I couldn't do what I intended initially -
So read, look, scratch yer head, ask questions, somebody'll chime in and eventually you'll be helping others with your newfound ejamicashun :D ... Steve
/ Hydraulic Fittings Confusion #3
On a lot of my stuff, I like to have my hoses wind up being JIC female. So frequently regardless of the connections of components, I find adapters that match the component threads, but have JIC male on the other end. That's just me. I keep spare hose and a spare reusable female JIC fitting around of each type in case I break one. That way, I can usually fix any busted hose issue without having to go to town. I do keep some JIC male reusable in case I have to cut out a piece of hose and patch temporarily, but I really don't see that happening.
/ Hydraulic Fittings Confusion #4
1 See BukiCase's post
2 Agree. NPT ok- SAE/ORB superior. JIC great-ORFS superior.
3 Yes. You can find cylinders with SAE ports at Surplus Center and other places.
4 Some use NPT since it's the least expensive. I think adapters make sense. I use them.
5 I tend to avoid NFT fitting, but if a cylinder or valve had them I would use an adapter so I only put the adapter into the cylinder or valve once and leave it. Same as EE_Bota I like hoses with female JIC swivel fittings. Easy to find, can be taken a part multiple times, seal better than NPT. So I would use adapters. Next step up from JIC fittings are ORFS fitings.
/ Hydraulic Fittings Confusion #5
for those of you NPT haters.. they do make swivels with a sealing shoulder.. so once you get the taper section secured and not leaking int he parent material.. then you can tighten the swivel yo your hose and go.
some of us old tractor owners had to get good at this instead of waiting fo rthe new tch to get here and do the work for us.. ;)
/ Hydraulic Fittings Confusion #6
Not exactly on topic here, but I see a link to "discounthydraulichose.com" and thought it might help someone out who's dealing with a hydraulic problem or doing some down home fabricating. I got an e-mail from them yesterday stating that if anyone places an order between now ant the 10th of December that they can get a 15% discount by typing in the word HOLIDAY in the coupon section. Not a big window of opportunity, but a pretty good deal for anyone that is ready to order. Came a couple days too late for me.
/ Hydraulic Fittings Confusion #7
I just ordered some fittings from them and everything came in good order etc. I had 3 day select as my shipping method and they called to let me know I would have it in 2 days going with ground......so kudos to them!
/ Hydraulic Fittings Confusion #8
Yeah, I got that 15% email shortly after posting - too short a window for me too, I'm nowhere near knowing what all I'll need for all the mods I'm looking at for the Case, still working on the Allis. Maybe next time...
Speaking of wierd ports, just checked this cylinder out. Note the DIFFERENT push and pull ports. Huh???!?
https://www.surpluscenter.com/item.asp?item=9-7850&catname=hydraulic
There's a couple like that. New to me... Steve
Thanks to all who answered. Good stuff.
Much appreciated.
-unixkid
/ Hydraulic Fittings Confusion #10
I used to think that jic only came in even numbers. 4-6-8-10-12-etc. Until I got hold of a old McCormick long arm mower. That thing actually had #5 jic ports. Liked to drove me crazy thinking it was some kind of metric oddball fitting. What was really unusual was that the local Carquest autoparts store actually had them in stock.
/ Hydraulic Fittings Confusion #11
Yep, all the old Ford/New Holland industrial tractor had -5 JIC fittings for the power steering cylinders.
/ Hydraulic Fittings Confusion #12
The dash "-4,-6" is the diameter in 16 ths of an inch. Also next time your in a pinch and all you have Is a jic fitting and an orb/sae port just grab a bonded washer or oring and your back in business, they both have sae threads just the sealing surface is different.
/ Hydraulic Fittings Confusion #13
Unixkid:
Think of hydraulic fitting types in the same manner as the numerous flavors of UNIX/LINUX out there...confusing as he!!. My only advice is to avoid NPT fittings if at all possible as NPT is evil in my book. Also, don't make the mistake of using NPT plumbing fittings from Home Despot in your hydraulic system. Plumbing fittings aren't made to the same exacting standards as hydraulic fittings are.
2021 CATERPILLAR 313GC EXCAVATOR (A60429)
2021 CATERPILLAR...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
