3 point hitch stuck on M8540
   / 3 point hitch stuck on M8540 #1
shooterdoc
farmall 450
New tractor (100 hours). New Meteor snow blower with hydraulic chute. Used the snow blower for the first time today. Moved a bunch of snow. Raised and lowered the 3 point several times with no issues. Raised the 3 point hitch/snow blower to clean before put back into shed now it is stuck in up position. Any ideas?
Thanks,
Jay in Iowa
   / 3 point hitch stuck on M8540 #2
Thanks,
Jay in Iowa
Did you try rotating the drop rate control valve counterclockwise? If it got bumped (rotated) closed, the 3pt will not drop.
James K0UA
   / 3 point hitch stuck on M8540 #3
Yep, I'm with k0ua, you've probably closed the drop rate valve accidently. Not much else to go wrong there. Of course we both are assuming you have the draft control lever pushed all the way forward???
   / 3 point hitch stuck on M8540 #4
Those are the only 2 things I can think of that would cause that.
E/S
E/S
Checked both of those things (and the linkage to the control arm/lever). Still doesn't work. Thanks for the replies.
   / 3 point hitch stuck on M8540 #6
Sorry to hear that, I am thinking broken parts inside now. Piston stuck, something clogging drop valve orfice, something like that.. I see a teardown in your future.
   / 3 point hitch stuck on M8540 #7
Time to call the dealer.
E/S
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Danuser Digger F-8 (A52128)
Danuser Digger F-8...
2018 CATERPILLAR 259D SKID STEER (A51242)
2018 CATERPILLAR...
