More progress on my 135 rebuild
   / More progress on my 135 rebuild #1
Forester Massey
Bowling Green Kentucky
Massey 135
Things are moving along and with another few hours or so I can turn the key and hope for the best. Today was nut and bolt day as I got distributor in, starter, generator, manifold, carb and other misc parts. Its just was not possible to torque manifold bolts down and that bothers me as I know the potential for problems later. If someone knows the secret, please tell. All I have left is to mount the tank (needs painting), fuel line, radiator and hoses and battery. Front end also.
I previously mentioned taking the clutch and getting it redone completely. As I stepped on the pedal I could feel the first clutch grab but ran out of travel for the second to engage. I have read the thread on clutch and noted the shop manual. I am hoping I can get it adjusted without much problem.
I also noticed just how dried and old the wiring system is on this model. I have also found its not an easy harness to buy at all. I hope it works enough to get me started and I can work on it later.
Lastly, I am hoping I got all my connections right on starter, generator etc. Electric I my weakest know-how. Pretty sure I got distributor correct. Any advice welcome.
   / More progress on my 135 rebuild #2
Did you follow the wiring diagram from the OP manual?
   / More progress on my 135 rebuild #4
No pictures???.
   / More progress on my 135 rebuild #5
I found the diagram in the shop manual. Forgive me but I don't know what OP means. Are you saying their is a diagram on the tractor? The tractor is in my friends barn and its not well lit. I will get some pics when I get the front end on and out in the sun.
   / More progress on my 135 rebuild #7
OP= Operators manual.
   / More progress on my 135 rebuild #8
I thought it was "original poster" or sometimes referred to as the "operator". Is there a manual that comes with this forum? :)
   / More progress on my 135 rebuild #9
Which bolts are you referring to on the manifold? Top ones or end?
   / More progress on my 135 rebuild #10
Sometimes I think there should be.
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2020 DRAGON ESP...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
