More progress on my 135 rebuild
   / More progress on my 135 rebuild #1
Forester Massey
Bowling Green Kentucky
Massey 135
Things are moving along and with another few hours or so I can turn the key and hope for the best. Today was nut and bolt day as I got distributor in, starter, generator, manifold, carb and other misc parts. Its just was not possible to torque manifold bolts down and that bothers me as I know the potential for problems later. If someone knows the secret, please tell. All I have left is to mount the tank (needs painting), fuel line, radiator and hoses and battery. Front end also.
I previously mentioned taking the clutch and getting it redone completely. As I stepped on the pedal I could feel the first clutch grab but ran out of travel for the second to engage. I have read the thread on clutch and noted the shop manual. I am hoping I can get it adjusted without much problem.
I also noticed just how dried and old the wiring system is on this model. I have also found its not an easy harness to buy at all. I hope it works enough to get me started and I can work on it later.
Lastly, I am hoping I got all my connections right on starter, generator etc. Electric I my weakest know-how. Pretty sure I got distributor correct. Any advice welcome.
   / More progress on my 135 rebuild #2
Did you follow the wiring diagram from the OP manual?
   / More progress on my 135 rebuild #4
No pictures???.
   / More progress on my 135 rebuild #5
I found the diagram in the shop manual. Forgive me but I don't know what OP means. Are you saying their is a diagram on the tractor? The tractor is in my friends barn and its not well lit. I will get some pics when I get the front end on and out in the sun.
   / More progress on my 135 rebuild #7
OP= Operators manual.
   / More progress on my 135 rebuild #8
I thought it was "original poster" or sometimes referred to as the "operator". Is there a manual that comes with this forum? :)
   / More progress on my 135 rebuild #9
Which bolts are you referring to on the manifold? Top ones or end?
   / More progress on my 135 rebuild #10
Sometimes I think there should be.
2007 Yamaha Rhino 660 (A56436)
2007 Yamaha Rhino...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
Toro z turn (A56859)
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A56436)
Bulk Lot of over...
TANK MANIFOLD (A58214)
