Jinma 224 Glow Plug Fuse Blows
   / Jinma 224 Glow Plug Fuse Blows #11
Each plug you remove should have a copper sealing washer attached. Often they stay in the hole. So make sure you have all 3 washers out before installing your new plugs. And install a new set of three, don't just replace the bad pair
   / Jinma 224 Glow Plug Fuse Blows #12
Also with these things they tend to bind up from carbon buildup so you may need to work them back & forth a bunch to get them loose and spray in some penetrate if they dont come out right away.
Others told/warned you about the copper washers they can be a pain in the BUT you can get them out if careful.
Watch for garbage around them use some compressed air to blow out rust & debris from around them.
Be sure to clean up the contact points on the Copper Bus Bar and use a bit of Elec Grease on the contact points when going back together. Also as mentioned replace them all as a set, they come with NEW copper washers and be sure to keep an eye on them, I lost one and had to use one of the NEW non-fitting ones I had.
Mark
   / Jinma 224 Glow Plug Fuse Blows #13
I wonder if glow plugs would be easier to remove if the engine were to be thoroughly warm first.
I think so, yes. Perhaps I can warm up the place around the glow plugs with a warm airblower? A good idea??
Jack
   / Jinma 224 Glow Plug Fuse Blows #16
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
378467 (A51572)
378467 (A51572)
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
