Jinma 224 Glow Plug Fuse Blows
   / Jinma 224 Glow Plug Fuse Blows #11
Each plug you remove should have a copper sealing washer attached. Often they stay in the hole. So make sure you have all 3 washers out before installing your new plugs. And install a new set of three, don't just replace the bad pair
   / Jinma 224 Glow Plug Fuse Blows #12
Also with these things they tend to bind up from carbon buildup so you may need to work them back & forth a bunch to get them loose and spray in some penetrate if they dont come out right away.
Others told/warned you about the copper washers they can be a pain in the BUT you can get them out if careful.
Watch for garbage around them use some compressed air to blow out rust & debris from around them.
Be sure to clean up the contact points on the Copper Bus Bar and use a bit of Elec Grease on the contact points when going back together. Also as mentioned replace them all as a set, they come with NEW copper washers and be sure to keep an eye on them, I lost one and had to use one of the NEW non-fitting ones I had.
Mark
   / Jinma 224 Glow Plug Fuse Blows #13
I wonder if glow plugs would be easier to remove if the engine were to be thoroughly warm first.
I think so, yes. Perhaps I can warm up the place around the glow plugs with a warm airblower? A good idea??
Jack
   / Jinma 224 Glow Plug Fuse Blows #16
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2006 John Deere 925D Header W/Trailer (A53117)
2006 John Deere...
2013 Chevy Silverado 2500 HD (A53473)
2013 Chevy...
