"Budget" Barndominium Build Begins
   / "Budget" Barndominium Build Begins #21
That metal for the framing had to be expensive...
   / "Budget" Barndominium Build Begins #22
I bet the foam insulation is necessary due to condensation of the metal?
Did you have someone spray it on for you with equipment, or did you order a kit?
I'm doing a metal quonset hut home and am at the point of deciding what to do
Not too bad. My helper's brother works for a metal supply company....:)
It's so dry where the barn is that condensation will likely never be a problem.
I had the foam sprayed in by a contractor. Foam has a long pay-out but I don't intend on selling in my lifetime....
   / "Budget" Barndominium Build Begins #25
I might be too late in some areas, but if you use cheap felt paper behind the barn boards all the seams will disappear. I like to use recycled boards for wainscotting and it works very well.
   / "Budget" Barndominium Build Begins #26
I hear you on the long payout, but I'm in the same boat, dont plan on selling ever....
Now, I heard that metal sweats easily when the inside space is air conditioned/heated. If it is really hot outside, and you run a/c inside, that the metal will sweat?
I'm planning on painting the outside with Coolseal from lowes, then use closed cell spray foam on the inside...
can you tell me how much it cost you to do that amount of space?
keep the updates coming :thumbsup:
OK time for an update. Deer season and work-related travel and holidays slowed down progress a bit but things are ramping back up now. The HVAC unit is installed and works like a champ. The foam insulation really is doing it's job. The other night we went out and it was 53 in the BB and we turned the heat on. It took about 5 minutes to reach 65 and then shut off. We stayed out there planning/looking/talking for 30+ minutes and the temperature held- the unit never came back on. We had the simple spiral ducting used and it works just fine.
The living area is complete now except for some outlet/switch covers. All the fans are up and the wiring is ready for the big-screen tv.
Bedroom is ready- fan up, closet painted.
Shower will be tiled in this week. We found some 67 cent tiles on sale and so that's good to go.
Used OSB board with a couple of coats of paint in the kitchen area.
Had some old feed sacks laying around so they were used to wallpaper the dining area wall. Going to add a few more pieces and then seal it in this week.
TIme to start building in the cabinets/sinks/etc.
   / "Budget" Barndominium Build Begins #28
That's quite the guest room you're building. Love the wallpaper!
   / "Budget" Barndominium Build Begins #29
It looks fantastic. Love all the old wood and feed sacks on the wall. Did you use Hodge Podge to put it up? How are you going to seal it?
Eddie
   / "Budget" Barndominium Build Begins #30
Barn is looking great! Question: why did you frame out the back wall w/ 2x4s (especially on a budget? I will be doing a similar build and was planning to use nailer boards on the inside in lieu of 2x4s since there is no real wall load.
Trail King 20ft T/A Flatbed Equipment Trailer (A51691)
Trail King 20ft...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 78"...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
