8N PTO HOOK UP QUESTION
   / 8N PTO HOOK UP QUESTION #11
I have an Over-Ride clutch on my 8N shaft so I dont get pushed around with mowers etc.
sherpa
   / 8N PTO HOOK UP QUESTION #12
Aside from your PTO issues, which have been addressed by other posters, you have a more fundamental problem. You will soon learn that your 8N is not suitable for three point snow blower work as the gearing is much too fast, the tractor lacks live PTO, and the power is insufficient for all but the very most ideal conditions.
SDT
   / 8N PTO HOOK UP QUESTION #13
and if it's rear.. you get a kink in yer neck.. :)
   / 8N PTO HOOK UP QUESTION #14
sherpa
Is that the same as an overrunning coupler? That's the first thing, IMHO, that needs to be done to an 8N that doesn't have one. My cousin has a rather hair-raising story about a brush hog, an 8N without an overrunning PTO, and a cliff in Arkansas...
I loves me some 8Ns, but not having live power is a definite drawback for some tasks--particularly if, say, your lift can't hold its position without the pump running...
   / 8N PTO HOOK UP QUESTION #15
naw.. that's what depth limit chains 'r for.. :)
   / 8N PTO HOOK UP QUESTION #16
They work well for some things (I use a cable/pulley system to hold the drawbar for the hay rake), but they're not much help when you're trying to use a boom pole to maneuver red iron beams out of an obstacle-laden area--step on the clutch to control the speed, down goes the lift. That'll flat out make you crazy... :confused2:
   / 8N PTO HOOK UP QUESTION #17
you must not understand how a depth limit chain works.
the chain holds the 3pt at it's minimum allowed depth, with no help from the hyds.. YOU set the depth based on chain length... can't drop when you hit the clutch unless toplink rocker rips out or chain breaks... yet you can still LIFT the 3pt higher if pto is turning.
sounds like it would be fine for that situation..
that or just actually oh.. FIX the issue.. IE.. a oring and washer on a nAA piston, and 5$ of paper gaskets.... 4 hours ( if you are slow ) of low grade wrench turning..e tc.
   / 8N PTO HOOK UP QUESTION #18
No, I understand how it works; as I said, I use a similar concept to hold the lift height when I have the rake on the drawbar. I do not, however, have a chain setup for the boom pole.
FWIW, my 8N has a fixture at the base of the top link mount with a pulley to accommodate a chain, but the tractor in question isn't mine (plus, my hydraulics work just fine). The owner (my dad) has fixing the 8N's hydraulics on his to-do list, but having a triple bypass earlier this year has kind of backed up his to-do list...
   / 8N PTO HOOK UP QUESTION #19
a standard depth limit fixture pins and unpins from the toplink rocker in seconds and is very portable, so would be easy to swap one onto a machine if needed.
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
FRONTIER AH11G LOT IDENTIFIER 100 (A53084)
FRONTIER AH11G LOT...
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
Billy Goat Blower Paint Dryer, 6.5 Briggs (A52384)
Billy Goat Blower...
