Why you should change your oil
   / Why you should change your oil #111
I alway's see on these threads the old trucks towing 20,0000 pounds and getting 25 miles to the quart and have thirty gazillion miles on it. Good Grief Charlie Brown what does anything have to do with anything?
If you are being sarcastic then say so...Tone of voice doesn't work in forums..Just what is typed.
   / Why you should change your oil #112
   / Why you should change your oil #113
I didn't go to the moderator and complain. I know complaining about brand bashing to them is frowned upon, so I didn't do it.....even if it's against the rules....lol
Its not frowned upon that I know of.
Aaron Z
   / Why you should change your oil #115
If you don't get then forget it.
   / Why you should change your oil #116
excuse the ignorance, but what is YMMV?
your mileage may vary.
as in.. not everyone gets the same results on everything, all the time.
   / Why you should change your oil #118
   / Why you should change your oil #120
hope hes not the kind that will say that's your fault!!
If it would have been Amsoil he could of easily run another 10K!!! watch out here they will come. haha
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Jumper Cables (A57149)
UNUSED FUTURE MCW39 39" HYD MINI COMPACTOR WHEEL (A58376)
UNUSED FUTURE...
1000 Gallon Fuel Tank (A57149)
1000 Gallon Fuel...
2006 SHOP MADE MARATHON 20KW GENERATOR TRAILER (A58216)
2006 SHOP MADE...
UNUSED JCT 72" HYD VIBRATORY ROLLER (A58376)
UNUSED JCT 72" HYD...
