Tooth bar....like we need another tooth bar thread
   / Tooth bar....like we need another tooth bar thread #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
OK OK I know there have been a gazillion tooth bars threads, but one more can't hurt.
I installed one on my last tractor, so I have experience using one and installing one, and yes, they are a great addition at a relatively small price. The one I previously bought was from the outfit in NC that is now Gator Attachments. I can't even remember the name prior to it becoming Gator. It was a good product and easy to install. Now I need another one for my current tractor.
So here's my question. Let me first say that I don't want to get into a lot of company bashing here, but I do recall a thread that was pretty critical of the Gator folks once they took over. Is that still the consensus? What brands are good both in quality and value? I figure you guys can save me a bunch of research time by letting me know your preferences.
   / Tooth bar....like we need another tooth bar thread #3
Like everything else, you'll get 11 different opinions from 10 different people. Then you will have to research to see which opinion is best. You can't win... :laughing:
   / Tooth bar....like we need another tooth bar thread #4
I bought from Long.
   / Tooth bar....like we need another tooth bar thread #5
Gator was Markham Welding. Lots of bad press a while ago, but I have not heard them even mentioned recently. The WR Long one is nice, Iowa Farm Equipment sells them online or a local dealer should be able to get you one.
The new one from BXpanded looks very cool also, I would seriously consider that if I was in the market: BXpanded Piranha Tooth Bar
   / Tooth bar....like we need another tooth bar thread #6
I bought one just last week from Iowa Farm Equipment. It came from a TISCO warehouse in Nashville Tennessee. Just give them your measurement and they most likely have one in a box on the shelf waiting for your order. That is the way it worked for me. It is 57 pounds, 6 teeth, 52.5 inch long for $325 and free shipping. It's heavy enough I'll never wear it out!
   / Tooth bar....like we need another tooth bar thread #7
I went with weld on teeth and have never regretted it once.
   / Tooth bar....like we need another tooth bar thread #8
I bought a WR Long flat bar thru Iowa Farm a couple years ago. The rugged teeth and flat underside bar worked great for digging in piles of dirt with small and large rocks as well as back dragging. I sold it with the last tractor. For my new tractor I'm considering the Piranha bar because there are no more piles of rock/dirt to move and the serrated blade would be more applicable to the roots/vines/turf in dirt now involved. The teeth on the Long bar were handy for attaching chain for lifting things, but now I have hooks bolted to the bucket that should be adequate.
   / Tooth bar....like we need another tooth bar thread #9
My tooth bar came Iowa Farm about 4 years ago. The tooth bar is for my 72" Kubota buccket and is rock solid. The one I got is not the flat bottom type. The tooth bar strenthens the bucket cutting edge.
   / Tooth bar....like we need another tooth bar thread #10
A toothbar is a hunk of metal that reinforces the cutting edge and has teeth that are removable (some are welded)...how hard can it be....choose size to match FEL, then look at weight and price. Nobody can tell if the welds will hold until years of use. I've actually never seen a toothbar failure report on TBN.
My toothbar weighs 130 lbs. It is a John Deere.
   / Tooth bar....like we need another tooth bar thread #12
Do a "Search" for "Grab Hooks"..."Bolt on" or "Weld on" Hooks and you will find many references and suggestions.....more than I would mention here. Happy New Year Mike
   / Tooth bar....like we need another tooth bar thread #13
I bought a 68" tooth bar on an online auction for $140.00 - less than half of the $350.00 that a new one costs. It's from an equipment rental store near KC, and is brand new. Going to have to cut 20" out of the center of it to make it fit my Kubota, but figure it's worth the work and risk.
   / Tooth bar....like we need another tooth bar thread #14
Actually... It has happened..this bar was never welded properly at the factory. As you can see in the photo the MIG weld never achieved any penetration on the bar.
http://www.tractorbynet.com/forums/kubota-owning-operating/200975-oh-oh-iowa-farms-flat-2.html
James K0UA
   / Tooth bar....like we need another tooth bar thread #15
I got mine last spring from Iowa Farm Equipment. Well built and shipped very fast. Love it
   / Tooth bar....like we need another tooth bar thread #16
Well, I'll be hornswaggled!!! Right you are...sucker busted right clean off...never thought a factory welder would have just barely tacked a tooth :shocked:
I stand better informed and corrected...thanks! I see several others have had the same thing happen, seems always to a flat bar. Never seems to mess anything up, simply weld back on properly and proceed.
James K0UA
   / Tooth bar....like we need another tooth bar thread #17
Makes you wonder if it was 4:45 on a Friday nite when he started on that one and had a pretty little gal waiting to go out with him:D
Or it was Monday morning, and he was the "just hired new guy." We will never know:)
James K0UA
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
