Leak at steering cylinder & other ??s
   / Leak at steering cylinder & other ??s #1
kw22614
Manassas, VA
Kubota BX1860
Maybe someone can explain to me why my power steering cylinder is leaking.
Some background; I have a brand new, <20hrs, not even broke in Kubota 1860 with FEL. The leak just started maybe 2 days ago and she's just been sitting.
As I understand it - the power steering only is 'power' when the engine is running, and when off - it turns like the old type tractors. My leak only occurs when the motor is running. It leaks when turning the wheel either way AND when it's just sitting straight not touching the wheel. It's comming from the seal where the shaft comes out of the cylinder only on the left (driver's) side. There's no visible damage to the seal, it looks exactly like the seal on the right side that's not leaking. The tractor has just been sitting for the last several days, unless a gremlin got inside and chewed my seal I have no clue what happened. Any ideas??
Also I've looked all thru my owner's manual and there's no mention of a power steering pump or resevoir to check the level. Anyone have an idea where it is, I've crawled all over and under looking for it.
Lastly, I know - most stupid question but, is the transmission and the hydraulic pump the same? Again in my owner's manual, all it talks about is checking the trans oil level at the dipstick in the back at the PTO, there's no mention at all about a hydraulic pump and resevoir.
Any help/info/advice is most appreciated. Happy New Year!
   / Leak at steering cylinder & other ??s #2
Yes, the power steering, transmission, loader, and three point hitch all use the same hydro circuit. Not sure why yours is leaking being so new but from reading the forums here others have had issues with those seals. I think they are easy to replace if I remember correctly.
Sent from my iPad using TractorByNet
   / Leak at steering cylinder & other ??s #3
Your dealer should be only too willing to make that right, considering it's a brand new machine. It may be something simple or may involve a replacement part, but either way, he should be all over it. And Happy New Year!
Thanks for the info Bob & Grandad. Been working on stuff all my life and thought I was going looney!
I plan on calling my dealer first thing tomorrow AM, hope they're not on vacation or something.
Also hope they don't charge me for transport. I reckon we'll see just how good they are. :crossfingers:
Thanks again, Happy New Year!! KW
   / Leak at steering cylinder & other ??s #5
This should be a warrantee repair like Grandad said. Good luck and if you get a minute post back when the problem is corrected. We all like to hear the final outcome. Pictures are always welcome too! (Hint hint)
Called my guy at the dealer this morning and yes it's definitely covered by Kubota. Now I just have to figure out how to get it to 'em, or pay their $195 there & back delivery charge. They said it'd be maybe 3 or 4 days to get it done as this is their busy season and they'd replace the seal.
Checked the seal before I called and all was dry. Then I started it and within about 1-2 min it started leaking again.
I'll keep posting as this reaches it's outcome... Here's a few pics so far
   / Leak at steering cylinder & other ??s #7
Thanks for the pics., The cylinder rod looks pretty pitted and corroded at the end. I wonder if that could be the reason for the premature failure of the seal? If you turn the wheel all the way does the rough section touch the seal?
Man, $195 for pickup is harsh, especially for a warrantee issue. Wouldn't take to many trips like that to pay for a trailer... Just sayin!
Yea, the rusty, pitted end just touches when all the way in. And this baby lives inside - on a persian carpet no less! Pits didn't come from me.
$195 harsh?? That's their discounted charge and I'm only 15 - 20 miles from 'em. (That's what living 40 miles from DC'll get you!)
I have a 5X10 trailer with 15" wheels and 3500lb axle. Loaded the little girl up (only weighs about 1900lbs), strapped her down and she towed and rode like a dream. I didn't try to break any land speed records. A few more pics...
   / Leak at steering cylinder & other ??s #9
My dealer has a service truck they send out to do the repair on site for small things like this. I had a warranty repair that they did in my garage and didn't charge me anything. Too late now, and hopefully there won't be a next time, but you might ask if they have such a service.
They do and I did ask, but he said this job can get messy and they can't be responsible for my garage. Just as well, pushed me to load and haul her on the trailer. Now I know it'll tow fine. Till now I thought my trailer was too light. I guess that's the silver lining! Thanks
   / Leak at steering cylinder & other ??s #11
Glad that worked, you might take your FEL off if you have to do this again, that would save some weight and take some weight off the tongue.
   / Leak at steering cylinder & other ??s #12
Glad you have a plan of action. I agree with BeezFun's suggestion about removing the FEL. That's something easy to do and very handy when the FEL isn't actually being used. Something to practice when you get the chance. Best of luck with the repair.
   / Leak at steering cylinder & other ??s #13
There is most likely another oil seal behind the wiper seal that is visible from outside, the inner seal is what holds back the oil pressure. Good side is they will have to polish off that rust to make the repair and if too pitted will have to replace the rod.
Those single axle trailers work fine for hauling the lighter tractors, if you can get balanced right. I hauled my first one (B8200) home on a 5'X8" with 3500# axles but my axle was closer to center of trailer and had to stop and reposition 3 times before I got it right. Bought a tandem axle trailer soon after that.
When I dropped her off they told me this had happened before, infrequently, on other new tractors as well. Something about Kubota buying the cylinders in bulk and they sit around until installed sometimes allowing enough moisture inside to cause rusting. So yes, most probably an inner seal. Kinda hope they do replace the cylinder, that way both sides will be new and I won't need to worry about or expect the same thing on the right side.
My 1st go at trailering her, but I must have balanced her well. She rode very well, no sway, no bucking, no bouncing or banging on the tongue. When I bought in Nov, sales-guy took off the FEL just short of pulling the hyd conns, so I've seen it done but don't hav any 1st hand exp yet.
Only been with me for 1&1/2 mos, we're still just going steady - will get to the hardcore stuff soon enuf! :laughing:
Thanks Grandad, probably give it a go soon after I get her back. First I need to stiffen up my trailer ramp/gate with more angle. I'll post again regarding the repair... KW
   / Leak at steering cylinder & other ??s #16
I use a similar 10 ft. trailer with my BX and likewise had to reinforce the ramp. Added a 1/4" x 2" angle running the length of the ramp under where each of the tires track when climbing the ramp. That has worked well for about 8 years of use now. Another suggestion is to get a pair of small jackstands to place under the back of the trailer when running your BX up or down the ramp. That avoids putting the entire weight of the BX on the back end of the trailer and putting a lot of upward pressure on the tongue and coupler while you're loading/unloading it.
I was wondering exactly how to easily stiffen the ramp. Good idea with the stands.
I'm afraid my little mig welder will only burn 3/16" at it's HIGHEST setting, but maybe 2 back-2-back under each tire would work though. Originally I was thinking of adding 2 vertical lengths between the 2 there now, on each side and then some horizontal peices, like laddering between them all. But I think easier and less is better. Besides I know I'd run out of gas doing all that.
Hmmm, got the wheels aturnin' and the smoke arollin'. :scratchchin:
Thanks again, Grandad!
   / Leak at steering cylinder & other ??s #18
A simple and crude reinforcement would probably be just a couple of 2x10's bolted or temporarily placed on the top of the ramp. They wouldn't be enough for the tractor by themselves, of course, but should do some good in combination with the ramp itself.
Need the welding practice. Hope to get to the metal yards tomorrow and pick up a 20' lenght of 3/16 X 1 1/2 angle. Cut that in 4 and still have leftover.
I'll have to wait to get the tractor home to see about placement.
Called the dealer this morning to check on my BX. He said the mechanic had it in Fri and ordered a cylinder rebuild kit. Not sure when it'll be in but hopefully won't take too long to install when they get it. I hope they rebuild the entire cylinder so I don't have to worry about the right side later but he wasn't sure what the kit included. I also heard that alot of BX and B model's front axles come from the factory low on oil so I asked them to check and top off if needed and if this was covered by warranty. It's covered and they will.
2 birds with 1 stone! :hotdog:
iDrive TDS-2010H...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Kubota ZG222 (A60462)
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2014 Aerway Aerator (A55973)
2014 Aerway...
