Inventing a new attachment
/ Inventing a new attachment #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
First if they say necessity is the mother of invention, I need a new mama. I do not have a quick hitch. I have a pin on bucket. Now a days, the bucket is used the least of everything I have but it has an important role in that it serves as a mounting platform for tines, teeth and forks. As I skid logs in winter, I need an attachment that A. is able to pile logs, B. is able to plow snow better than what a bucket can do. C. can mount forks to. D. can make any of these change overs in seconds. I wish I had C.A.D. to show what this might look like but I'm thinking of a 4' wide "blade" used to pile logs and go through the woods easier that one can quickly pin on snow containment sides (sort of like a snow pusher) that make it 6' wide. I already made dismount forks so that's the easy part. Its about how this can curl and hold a tree stem without getting in the way of plowing snow. Any ideas would be welcomed.
Simple, change your loader to quick hitch and everything is avalable most anywhere including a grapple if you like. Here is and example.
Tractor Loader Universal Skid Steer Quick Attach Hitchs
John Deere also makes there own type of hitch but the attachments are usually more expensive.
The point of this is to not spend $1000 on just the quick hitch as that part is not "simple" for me. As my bucket has a rounded back, an adapter would be a hard fit and I would still have to make the pusher.
/ Inventing a new attachment #4
I don't know right off what your lift capacity is on the 750 but it would seem by the time you get all the gadgets worked out it may be more weight than you would want. If it were me I would address the real problem which is the lack of quick attach, I would build that if necessary and have separate tools that would work well.
I do quite a bit of clean up work with my tractors and find it quite alot easier to cut and load firewood then chip the limbs on the spot eliminating a mess to clean up afterwards. Lot better for the soil too.
/ Inventing a new attachment #5
I just posted in the other thread and then ironically, I saw this one.
Any type of blade you "add" to the forks and plan on leaving on, will reduce the lift capacity for logging.
I know its the wrong time of year, but why not look for a truck mounted plow. In the spring, they can be had for cheap. $200 would buy a plow worthy of personal use. You can easily adapt to a loader as many have already done. If you dont want the complexities of hydraulics, most plows can be pinned and manually angled. So just pin it straight, and adding wings is easy.
No you are right about the forks. They would have to be removed and not part of the attachment process. The forks would be mounted to the blade and as a result would actually increase lift capacity as they would not be sticking out so far as the current bucket makes them do. I cannot use the forks for stem piling as they have cut my loader lift drastically.
The plow idea is a good one as well but I'm actually looking to ditch the bucket for winter. Would need to make pin on mounting brackets and slice a foot off each side and come up with some way of attaching grab points to lift logs. Might make a good platform if I could solve the log lift thing if the blade is not too heavy.
Actually jenkins this atachment should be lighter than the bucket with all its stuff on it. The other advantage is that a "blade" would provide an in closer attachment point making lift increase.
/ Inventing a new attachment #8
Can you make a plate or frame that the plow pins to and then that frame pins on the loader arms??
I must have edited my above post while you typing in this one. To reiterate; that's exacly what would be needed to do. Darn, I know I saw a $200 plow on some road I traveled last week. Why can't my head and life timing coincide just once.
/ Inventing a new attachment #10
Not sure how far away this is from you 8'6" Myers plow blade
But if it were near me, I'd buy it in a heartbeat.
But then again, I am actually looking for a 8.5' plow to replace my 7.5 since I got a bigger truck.
You could always cut it down, and could even make wings with what is left after you cut it down.....
Just saying:rolleyes:
You could always cut it down, and could even make wings with what is left after you cut it down…..
That's exactly my idea as well about the wings so i do not mind cuttting it down. What I need to be careful with is that as these plows get wider, they get taller and as a result weight goes up. The one I saw for sale last week was 6' wide which would have been perfect. If I could just remember where I was. Wherever it was it was only 15 minutes away from home :(
Tiverton is about an hour away. Thanks LD
/ Inventing a new attachment #12
I didnt think RI was that big:laughing:
Anyway...what is your lift capacity??
I am guessing in the 800# range. Take the bucket off and now you have 1000#+ capacity.
Most 8'6" plows are in the 700-750 range. Shouldnt be a problem if you remove the bucket and keep it in close.
Even dropping down to a 6.5 or 7' plow, you only drop ~150lbs, but then you still have to add the wings. Whereas the 8'6" plow, you can make the wings out of what you cut off. All in all, I dont think the smaller plow is going to be THAT much lighter when all is said and done.
Its not but the traffic is murder:)
Even if the plow was 6', Id still cut a foot off each side and make the wings with those. 6' wide anything in these woods is like wearing 3 extra shoe sizes.
/ Inventing a new attachment #14
Yah, driving in NE is comedy to us in the plains/midwest... When EVERYTHING is 4 hrs away and counties are bigger than NE states, a 1 hr drive is like a drive to a store... I've been in RI a few times, and it always made me chuckle "we're there ALREADY?!?!?" :)
Not sure what you really want to do, but the gist of life, in my years of experience, is "do it right, or do it over". You got by with the (rather ingenious) fork attachment for years, but anything beyond that means you really need a SSQA. I bet you can weld a plate onto the attachment brackets on that bucket to convert it. And probably not a huge deal for an experienced welder. You will not be able to believe how much flexibility a SSQA gives you.
I wrangled this sketch to show what I had in mind. This is the all around bucket I'd probably use the most as I hardly use a bucket for material. This bucket would only be 4' wide with the ability to attach 1' wide sides to make it into a snow pusher. This bucket could roll tree stems and curl them up for piling. I'd never take it off as it would even suffice for a makeshift materials bucket. Have seen buckets close to this but they are over $1000. I could probably build this for half that with 1/4" stock
/ Inventing a new attachment #17
that looks like a rock bucket but that should do what you wont it to.
/ Inventing a new attachment #19
If you are starting from just the one attachment (bucket), do yourself a favor and convert to SS type quick tach. You will appreciate the wide variety of ready-made attachments that fir the SS type attachment. And if building your own, the SS basic building block is available. Also, you could rent or borrow (or loan out) attachments easier if you were set up with the more universal SS type system.
View attachment 298986 Ahh, Looks very familiar!
It does but there are things that need to be changed on my design. For one the teeth need to be curved upward about 30*. This makes flipping a log into the bucket much easier. The second thing is if wanting to also use this as a snow pusher, provisions for extensions of about one foot per side are necessitated along with the extensions themselves.
