Picking up Fibreglass water tank
   / Picking up Fibreglass water tank #1
Robert M
Member
Delegate NSW
no tractor yet
Appreciate ideas on how to best pick up a water tank. I am getting a tractor with FEL and pallet forks and want to move a tank that is 3 m (18') in diameter. I have heard you can get pallet fork extensions but not sure if they are necessary given the limited use I would have for them.
   / Picking up Fibreglass water tank #2
Are you trying to load it or put it on a platform, or just move it? Set it up on its side and roll it?
The tank is currently on a rotten wooden platform and I want to lift it off the platform onto the ground or maybe onto some wooden pallets. I then want to repair a crack in the tank and move it to another site about 400 m away and place it on another platform close to the ground. Fibreglass tanks are not flexible like plastic tanks and would probably crack if I tried to roll it.
   / Picking up Fibreglass water tank #4
fiberglass can be heavy. a tank 18' in diameter is huge. you would need 2 big tractors at least with 6-8 foot pallet forks on each tractor. I would ONLY attempt to lift straight up in the air slowly and back a trailer underneath it and set tank on that to transport it even it it a short distance. it would eliminate any opps on the way cracking it more. I realize you would have the old platform in way - but since there are no pics - I am assuming you can cut the platform out of the way for the trailer to back in.
   / Picking up Fibreglass water tank #5
Sounds like you need some straps and a small crane to do this easily/safely.
   / Picking up Fibreglass water tank #6
My brother has a pair of "extensions" for his forks that are really only lengths of heavy rectangular steel. He slides them over the forks for long extensions. I think they must be a good 12 feet long or better. Just an idea to consider...
   / Picking up Fibreglass water tank #7
I have used hardwood planks chained to the base of the forks to lift a wide boat. Worked very well and wood is cheap. Especially if there is a saw mill close by. At your destination the planks could be used to slid the tank to the ground.
   / Picking up Fibreglass water tank #8
Is it 3meters {9 ' 9 "} or 18 ' feet in diameter ?
   / Picking up Fibreglass water tank #9
Either way my thought is its too big to fork
There is no information given on the size of the tractor, but this would be risky
with even a big wheel loader IF it had any water or other liquid in it. If the tank
is empty then its a different story, but still need to know the weight of the tank.
9'-9" is about 75 sf so that's roughly 560 gallons per foot of depth. (~7.5gal/cf)
560 gallons weighs about 4800 pounds. (~8.5lb/gal)
So weight of tank plus 4800# for every foot of water in the tank, you will be past
your safe lift capacity very quickly.
   / Picking up Fibreglass water tank #10
Several good pictures of the object in question would really be helpful, for more precise advice.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2022 Freightliner M2 106 Medium Duty Rollback Truck, VIN # 1FVACXFC5NHNM7347 (A51572)
2022 Freightliner...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
