PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"?
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #1
SanDucerro
Gold Member
Yoakum, TX
Kubota M7040 - L3130 - ZD326S
Like the title says - I'm fixing to order a PTO Post Hole Digger to "plant" 130+ 6" CCA Round Wood Posts. Do I want the 9" or the 12" Auger?
Seems the 9" is only going to give me 1.5" per side for backfill "room". Is that enough to tramp, or should I go 12" so I have 3" per side?
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #2
9 will be fine.
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #3
12" auger will give you more room, margin for error. Not every hole is going to be dead cneter where you planned it nor will the all be prefectly vertical. Especially the first few as you learn to sight the auger and move tractor fore & aft to keep the auger straight. There may come the time when a 9" would work better is some cases. If you can afford it get both.
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #4
The 9in will go into the ground easier but the 12in will be easier to tamp the post in the hole.
Maybe I should add that the ground is sandy loam and I don't think there is a rock any where on the property. I do have a hard pan in some sections about 36" under the surface. When we used a two man auger to plant the post for the house we hit that and literally couldn't go any further. It was almost like a shelf! Most of the property is easily dug though.
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #6
12 inch
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #7
for what your wanting todo a 9in auger would be just fine.but if your putting in big corner post you need a 12in auger.but honestly you need both the 9in an 12in augers.
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #8
It's not the size of the hole so much as it is getting it in the exact right place and angle. I have a 12 inch and red clay. I don't have any rocks, but I do have roots. My posts are 5 1/2 inches square. Getting them in a straight line, perfectly spaced every 8 feet exacly with a 12 inch auger is impossible for me every time. In fact, I'm lucky to get one in four just right and not have to use the clam shell diggers to make an adjustment of some kind. A hydraulic post hole digger would be better, but with a 3 pt post hole digger, you have to deal with position, and the angle of the downforce. Then you have to deal with anything that it hits while going down. It is VERY HARD to go straight down!!!!
I would never even consider a smaller auger for fence lines!!!!!!!!!!!!!!!!!!!!!!!
Eddie
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #9
12" for sure. Like others have mentioned, your auger will drift to one side or the other and not go straight down. Plus there are variations between where you intended to dig and where you actually dug as also mentioned by others. Backfilling and tamping is easier as well with a little room to spare.
   / PTO Post Hole Digger Auger Sizing for 6" CCA Posts - 9" or 12"? #10
will join the bang wagon, and say go for the 12" auger.
and have a second person acting as spotter, while digging holes, putting posts in and tamping. it reduces work about an easy half. (lots and lots of less leg work, and little bit better accuracy. but even still. a larger auger bit, like others have said, gives you that couple extra inches to tamp and line things up. when handling fence posts all day long, and then dealing with shovels. that little extra space is worth it. so much easier to tamp a little more dirt, than it is to shovel out a bunch of dirt.
hydraulic down force kit for 3pt hitch, for me would be extremely helpful for the various dirt / soils on the farm, but *shrugs* i have gotten on without it. with the old regular hand shovel and regular older two handed post hole digger.
having a reversible 3pt hitch post hole digger, when dealing with a bunch of roots. can extremely nice. so ya not having to break out a large pipe wrench, with cheater bar on it. to back out the auger bit when it gets stuck.
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
GMC 2500HD 4wd Service Truck (A56438)
GMC 2500HD 4wd...
CAT930K (A58214)
CAT930K (A58214)
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
