quick hitch
   / quick hitch #11
Maybe the case for your application but no matter what way you slice it, the pats system restricts the length of the top link. It's basic physics
Not to be argumentative, but the slide-in or weld-on Pat's leaves the tractor's 3PH geometry the same.
clee7020 may have already had a longer top link or at least one that could reach far enough. Besides, longer top links are cheap as are PTO extensions. It is the PTO shafts that seriously impact the budget.
   / quick hitch #12
wow. I am amazed at the various responses here.
In my opinion - the quick hitch is nice since the lower arms is "already" spread apart and same everytime you backup to hook up. pats depends on your tractor style. is there a spring on it? sliding or bolt style? With pats - you need to hook up the upper toplink manually everytime. The QH, the toplink hook up depends on the final hieght of your implement. I have one of those black qh's and sometimes I have to switch the hook part to fit various implements. I pulled the bolts out and use a wagon pin to speed changing heights.
   / quick hitch #13
You're right, I have the slide in model, but I had Pat build me a set that sticks out about an inch further than factory. I did this because my bushhog sometimes would hit my back tires. I still have plenty left on my top link. It also probably makes a difference that I have a 95 hp tractor. I imagine the top links on some smaller tractors would have to be replaced.
   / quick hitch
I agree with radioman. Why not make it as easy as possible. I have a flail mower, disc, rake, rototller, 500# spreader, all are very close to 26.5 centers, the only one would need adjustment is the top link on the flail is straight up and down needs to be modified to stick out.
   / quick hitch #15
I bought one of those black QHs from Harbor Freight a few years ago. It was under $100 and I figured if it's junk and breaks then I'm not out that much and I'll go with something better. It isn't the best thing made ...but I'm still waiting for it to break. I use it everyday - stays on the tractor unless the backhoe is on. There is an adapter for it that replaces the hook for matching up to some implements that won't do the hook.
   / quick hitch #16
I have a JD Cat 2 QH on a JD 7330 and I bought a Harbor Freight QH it put on the JD 4020. Our big stuff (subsoiler, planters, grader, hay forks, etc) is QH compatible with JD QH, but the Harbor Freight QH top hook (even though it is adjustable) is not compatible. I have no intention of using the JD 4020 or the Harbor Freight QH to pull a 7 or 9 tooth subsoiler or a 10' hydraulic grader blade, but I would like to have everything set up the same because I do use the 4020 to move hay, bushhog and other lighter duty jobs. So, so far my Harbor Freight has been useless.
   / quick hitch #17
Just curious as to why the HF quick hitch top hook is not compatible. As has been discussed here before, there are a couple of easy fixes that take care of some top hook issues. Some of the HF top hooks seem undersized because they aren't forged straight but a little grinding on the inside fixes that. The other problem is that some implements have a narrow top hook frame and the bolts on the QH interfere. This is fixed by using short pins so the bolt head doesn't stick out.
   / quick hitch #18
Their is a $12 adapter with the HF quick hitch if the hook isn't compatible. I bought both at the same time and it has been invaluable!! All of my attachments work except a king mutter rake. They welded the pins an inch to wide. It wasn't harbor freights fault. It needs to be 27.5" apart and te implement will work.
I have no experience with pats system. It was more money but I have never heard any negative comments about quality. The Harbor freight quick hitch just keeps on going too thou!!
   / quick hitch #19
no problem buddy, but the one pictued in the original post link offsets the attaching point by about 3 inches and can make a good bit difference to some. especially those using a hydraulic top link. It is not the same as stock at all. Now when you use a harbor freight quick hitch, it keeps everything the same length
   / quick hitch #20
Right you are about the hydraulic top link. In fact, that is why the Pat's that I put on was the kind that doesn't mess up the OEM geometry.
Just to state again, one must be careful with the PTO shafts that have to extend farther to reach the attachment point on the tractor. But for around $20 that can be remedied.
Pto Adapter 1-3/8 X6 Spline Male X 1-3/8X6 Spline Female Pto Adapter
ALLISON TRANSMISSION (A55745)
ALLISON...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
