Am i crazy for wanting wood barn?
   / Am i crazy for wanting wood barn? #1
sawtooth
Eden NC
Ford NAA, Ford 2810, Ford 3910-1, Ford 3910-2, Ford 4600SU, Massey 2660 HD, Massey 461, Grasshopper 725D, Grasshopper 900D
Im getting ready to have a barn built this spring. Problem for me is the type of materials. My family has owned our farm in Ohio since around 1850. All the structures have always been wood and i really want the new barn wood as well. BUT i know metal last longer so am i making a huge mistake going wood? Im looking at a 40x60x12 or something close to that size. Will hold equipment etc.
Lastly bats are a big issue to so need a tight structure too. If i do wood i want some sort of barrier like tyvek to keep stuff out.
Thoughts?
   / Am i crazy for wanting wood barn? #3
I see a lot of old wood Barns in Ohio
   / Am i crazy for wanting wood barn? #4
We have several barns in the area with the original 1880 slate still on the roofs. I also admire a wood hand hewn barn beam. To restore one would make sense but I do not Think building new would. A pole barn can be made as you want. Roofs and sides can be insulated if required. Cost will be high as even metal is no longer cheap. A friend has a nearby farm called , "Happy Chance". He poured a 1/2 mile stamped concrete driveway. Lottery money was used to do this. It is your choice.
   / Am i crazy for wanting wood barn? #5
I am not sure about metal outlasting wood barn siding.
Couple of things to consider, maybe the wood used years ago for barn siding was of a quality that is hard to find now, and it seems like wood barns last about forever if the roof is kept in repair and they have a solid foundation.
   / Am i crazy for wanting wood barn? #6
You're not crazy. I have an all-wood pole barn. The previous owner built it so I don't know what it cost, but he was cheap and it seems cheap. But it has stood for 20 years now. The walls are vertical tongue and groove pine over 2x4 girts on 24" centers, and the roof is asphalt shingles over 1/2" sheathing on top of 2x4 purlins on edge, on 24" centers. So it's pretty standard pole barn construction. I can get locally sawn and milled T&G for $1.50/SF which I think is competitive with steel siding. All my other buildings have cedar shingles, the last time I bought them I paid $1.22/SF for grade B's. I think that with 3/4" plywood sheathing shingles would work, that's about $35/sheet right now or another $1.10/SF. Board and batten isn't popular around here, but if I wanted to go that route rough cut lumber is running about $0.80/SF now for pine and about twice that for cedar.
Now what's crazy is thinking your barn can be bat-tight!
   / Am i crazy for wanting wood barn? #7
The only issue is fire and that could come from an acccident or a lightning strike. A lightning hit in a metal barn just blows a hole in it and, God forbid, a welding spark in a metal barn is usually less risky. Better idea is a beautiful and ornate wooden shed and a separate metal barn but that's just my opinion.
   / Am i crazy for wanting wood barn? #8
I think around here, hemlock is cheaper and lasts longer than pine. Of course cedar would be great but expensive and harder to find.
I certainly would want modern truss construction (clear span) if it is going to be an equipment barn, you don't want center supports in your way!
Bats are great bug reducers :)
   / Am i crazy for wanting wood barn? #9
Wood barns are beautiful! I just built mine. It's 36' x 36', pole frame w/ 1x12 rough-cut pine vertical siding. 16' wide center aisle without center posts. Built the trusses myself. Already have mice building nests and need to get a few barn cats! :) Metal barns are just big metal boxes. No character. Depends on what you're looking for. I did a lot of the labor myself except for the roofing and setting the posts and it cost somewhere around $20k.
   / Am i crazy for wanting wood barn? #10
I think it depends on what you want. I built a wood barn, 40x40x12 in 1989. I have had to stain it 3 times so far, and it takes quite awhile to do so. I've got friends that have very nice Morton barns, all steel, very nice. If you do go with wood, if you use T111 siding, make sure you get the real plywood T111, they are selling a usb T111 now, and I don't think it is as good.
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
38501 (A51691)
38501 (A51691)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
