EddieWalker
Epic Contributor
How are you attaching the interior walls to the exterior walls?
Eddie
Eddie
Eddie
We did have to contact the soil conservation unit of the county. We were under the threshold amount of disturbed soil so did not have to put one up.
Two concerns from the pictures that I don't understand from where the interior wall stud is attached to the exterior wall. I understant how top plates work and the different between load bearing and non load bearing. But every house moves and every house gets its strength from how the parts are tied together.
First concern is that the connection from load bearing exterior wall to interior wall gains tremendous strength from tying the studs from both walls together. I've never seen or thought of doing it any other way. I don't even know what code is on that, or if it's legal or not. I'm guessing it is since you are getting inspections and your framing is something that the inspector will be looking at. It's just something I've never seen and don't see any reason to do it that way.
The second concern is attaching the sheetrock to the exterior wall. How does it get attached to that inside corner where there isn't a stud? Do you cut out the foam and put in blocks of wood? I like to use five screws for every four feet of sheetrock, or a screw for every foot when installing sheetrock. How do you get that many screws into blocks without having a full length stud in the wall?
Eddie
They make inside corner drywall clips, they are used in super insulated homes, to eliminate blocking.
Dave
