converting pto to hydraulic
   / converting pto to hydraulic #1
chappy66
coleraine MN
2410 bobcat
I have a toro 150 snowblower with pto drive and need to covert it to haydraulic for a college project. Im attaching it to a 2410 bobcat front end loader with a 26.7 gpm Where do i start.
   / converting pto to hydraulic #2
They sell a hydraulic pump that fits on standard PTO splines. If you look at the ads on this site Surplus Center carries them.
   / converting pto to hydraulic #3
   / converting pto to hydraulic #5
Don't ask me nothin' about no stinkin' snow!!! ;) ;) (I escaped it!!)
   / converting pto to hydraulic #6
How big is your plow from what I googled it looked like it could 50 inch or more,you have 66 hp it appears and 26 gal at prsumably full throttle that is way more than enough power to smash a 50 in.plow .I am not a hydraulic tec but since no one else seems prepared to help I will assist to a limit ,you will have to do some calculating you probably will need to install a cheap manual flow control then it will give you a bit of flexability in the size of motor you choose .Your flow control should be sized up to near the 26 gallon so it will work well with that volume ,thenlook for a motor that will give maybe 30hp with 540 (this is my guess that the pto speed would be) if you khow for sure what it turned at that is what you must aim for.
After you determine the motor you will need to develope a coupler (Surplus centre may have the right configuration of that also)to match the shaft on the plow and the motor .When you fabricate a motor mount you will need to be very precise with alignment so as to not ruin your shafts and coupler from wobble .
The math I mentioned will be to convert your gallons to RPM ,keeping in mind you have some freedom because of the flow control but remembering to get a motor with enough torque to give HP high enough to drive the plow .
The flow control will be positioned between the skid steer breakaway and the plow motor.
Hope this can get you started in somewhat the right direction ,you have a good project going good luck.
   / converting pto to hydraulic #7
How much HP did the snow blower require using PTO?
If you use a hyd motor, it will have to spin the rotor at a similar speed.
And of course you need the torque.
Assuming the snow blower took 20 HP to turn the rotor at 540.
20 GPM flowing through a 8.5 cu in hyd motor will turn it at 544 rpm, and the torque would be about 3384 in lbs or 282 ft lbs
The pump that pumps the 20 GPM, at 2500 rpm, at a 2500 psi potential, would use about 34 HP
26.5 GPM would require about 45 HP, and
You could run a larger hyd motor and obtain more torque.
Surplus Center - 7.63 CU IN PTO DRIVE MOTOR
Surplus Center - 9.59 CU IN PTO DRIVE MOTOR
   / converting pto to hydraulic #8
Thanks J J I knew I didn't have the knowledge you have and I was just trying to kick start the lads thread.
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
1999 CATERPILLAR 963C CRAWLER LOADER (A52707)
1999 CATERPILLAR...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2016 MACK CXU613 MID-ROOF SLEEPER (INOPERABLE) (A55745)
2016 MACK CXU613...
