problems with fuel in cold weather
   / problems with fuel in cold weather #21
The bottom line is run the power service. I have never in the 30 years of driving diesels had one gel on me. I buy fuel from 1 vendor and when I don't I add power service. It also adds lubricity to the fuel, granted the newer injection systems are designed to run on the "dry" fuel but it can't hurt. I don't worry about it in the summer, maybe every 20 tank or so just to keep the algae down. When I worked for a oilfield hotshot company we had trucks jell when the drivers filled at filling stations [we had a 15000 gallon tank at our location] We would pull the fuel filters off and fill them 1/2 way up with 911powerservice and added the rest of the quart to the tank and that normally got the truck going. If not then the pick up was gelled/froze and you had to heat the tank. Not fun at 30 below zero. Powerservice is cheap insurance for me. CJ
   / problems with fuel in cold weather #22
Power Serve or most any other additives dont do anything to prevent algae. You need to add a separate biocide for that.
Chris
   / problems with fuel in cold weather #23
Power Serve or most any other additives do anything to prevent algae. You need to add a separate biocide for that.
Chris
I must have been fed a line of b/s then, not the first time:) CJ
   / problems with fuel in cold weather #24
Power Service does make an additive Bio Kleen that they claim will take care of bacteria and fungi growth. Their standard Diesel Fuel Supplement makes no such claim.
   / problems with fuel in cold weather #25
I have only experienced algae 3 times that I can remember and 2 of them fuel was purchased from low volume mom and pop stores where the fuel sits for well who knows months/years. I always tell my customers never buy from low use stations. We would purchase a algaecide from our fuel supplier that worked very good. In my personal truck a 7.3 with well over 100k on it I have changed the fuel filter 2 times and both times it looked like new. Always buy from high use stations. I would say 95% of the fuel I have put through the truck has come from 1 fuel cardlock. The fuel system on a diesel is the heart of the engine and if you keep it clean and the fuel good you will have very few problems. CJ
Case Titan 3530 (A55218)
Case Titan 3530...
2009 Sterling AutoCrane 10006H 5 Ton Mechanics Crane Truck (A52377)
2009 Sterling...
JOHN DEERE 850K WLT CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
