are my front tires wimpy?
   / are my front tires wimpy? #31
I ran over a broken T post stub.
Last Fall I took out 1/4 mile of old fence and brush. I was very cautious about making sure I got the T posts pulled and not just sheared off. I was very paranoid about running over a broken steel post.
   / are my front tires wimpy? #32
I wouldn't change a thing on that tractor. Nice.
Yeah, I like that too. Overcomes that problem of R1s being so skinny. I would think those tires would handle the loader weight a lot better, especially in uneven terrain. That's what I was thinking about the European style for the front of my 9540.
RFB, are those the factory wheels or did you have to get wider ones??
   / are my front tires wimpy? #33
I owed over a T post with our M8540, but saw it in time on the return trip to avoid it, I have a picture somewhere, I also picked up a part of one with my rotary cutter that fortunately has foam filled tires.
   / are my front tires wimpy? #34
Kubo and ovrszd:
The rear tires are Kubota OEM R1 14.9 x 26.
The fronts are 11 R 16 Michelin XM27 Utility & Industrial. They have a R4 carcass and an R1 tread. They are only .5 inches larger in diameter and 1 inch greater in rolling circumference than the Kubota OEM 9.5 x 16 R1's. I have attached some pdf's showing data for them.
The front wheels are Kubota OEM R1 16 inch wheels.
I chose this after much research, and particularly after not enjoying the "water-bed" look of regular R1's with a heavy FEL load. I wanted R1 traction and R4 stability for my duties, and these provide both. I operate them at max psi since I never drive fast. (see the load ratings on the attachment.)
Here is a link for the Michelin page: MICHELIN XMCL tire, the backhoe and telescopic handler tire
View attachment Tractor front tires.pdf
View attachment R1W comparison for Kubota L.pdf
Hope this helps.
   / are my front tires wimpy? #35
RFB, thank you very much for all the info!!!
   / are my front tires wimpy? #36
Thanks for that info RFB. Never knew that tire existed.
   / are my front tires wimpy? #37
RFB, do you mind if I ask what they cost. I priced the standard Michelin tractor tire a while back but did not know about this tire.
   / are my front tires wimpy? #38
I spent a few minutes in the Michelin website that RFB provided above. It's awesome. With very little searching I was able to determine my OEM tire's specifications such as rolling circumference, which is the crucial issue. Then I searched for an equivalent in metric sizes which is considerably wider.
I found that I can run a 420/65R24 on my factory wheels and not disturb my gear ratios at all. I gain 2.8" of sectional width with each tire. That's a 22% increase.
I'll contact my local dealer and price a pair. Then after I get up off the floor, I'll post what I find. :laughing:
   / are my front tires wimpy? #39
No problem: I bought them in September 2010 for my 5030. They were still in excellent condition in 2012 when I bought the 5740 that I had the dealer mount them on the 5740 and put the new/oem R1's on the 5030 for trade-in.
Cost: 887.74 (443.87 each)
Freight: 128.38
Based upon my experience with them I would not want to go back to the oem R1's
   / are my front tires wimpy? #40
Thats not bad at all. I would have expected them to be more. I guess I am off to the tire dealer to check for availability.
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2019 TerraGator 7300 Spinner truck (A53473)
2019 TerraGator...
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
2005 FONTAINE 48 FOOT FLATBED (A53843)
2005 FONTAINE 48...
