In Search of Heavy Duty 3pt Disc Harrows.
   / In Search of Heavy Duty 3pt Disc Harrows. #21
Running a tandem disc with the rear gangs too low will tend to leave a ridge of soil behind the center of the disc while running with the rear gangs too high will result in the front gangs throwing up nasty ridges on each side of the machine which the rear gangs are not able to level out.
That helps explain an issue I'm having with ridges on the sides. I'll readjust the rear and see if I can correct. THANKS!
   / In Search of Heavy Duty 3pt Disc Harrows. #22
Looks like you're running a fairly fast ground speed as the front gangs appear to throwing the dirt out a ways. Not necessarily a bad thing, just saying.
The furrows are okay when tilling with the contour of the land but leave the potential for soil erosion from a heavy rain or snow runoff if tilling up and down hills.
   / In Search of Heavy Duty 3pt Disc Harrows. #23
You are correct on running fast. It is still a little wet. I don't have scrapers, so I went up a gear and keep it slinging. I have to run contours as my land rolls, rain has been plentiful over the last few months.
   / In Search of Heavy Duty 3pt Disc Harrows. #24
Please send your excess rain up to Kansas. We need it!
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
Informational Lot - Financing (A55315)
Informational Lot...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2021 TRAIL KING JBTR-47 (A55745)
2021 TRAIL KING...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
