MF T035 with bad carburetor. Carter UT
   / MF T035 with bad carburetor. Carter UT #1
toddsgarage
Sandy Lake,PA
JD 1070, MF TO-35
1955 ? ( T0-35 # 157980 ) .4-cyl gas motor Z 134 (618750 ) , Carter UT Carb . I am looking for a carb rebuild kit . No ser.# on carb but it has some casting numbers carter UT. 0-985 On the bowl. on the top flange it has 0-834. Yes it does stall on the hillsides. (keep the tank full it helps ) Should I rebuild if i can find a kit or replace ? what carb should i use. Thanks for your help.
   / MF T035 with bad carburetor. Carter UT #2
Did anyone ever respond to your question. I have the EXACT same situation with my T035 and it seems the float got stuck cause gas was running out the bottom hole of the Carb. So, I removed the carb and disassembled it but now I am in need of gasket and might as well do a complete or partial rebuild.
   / MF T035 with bad carburetor. Carter UT #4
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2014 Ag Spray Schaben Sidedresser (A56435)
2014 Ag Spray...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
Honda UTV (A56859)
Honda UTV (A56859)
TANK MANIFOLD (A55745)
