MF T035 with bad carburetor. Carter UT
   / MF T035 with bad carburetor. Carter UT #1
toddsgarage
Sandy Lake,PA
JD 1070, MF TO-35
1955 ? ( T0-35 # 157980 ) .4-cyl gas motor Z 134 (618750 ) , Carter UT Carb . I am looking for a carb rebuild kit . No ser.# on carb but it has some casting numbers carter UT. 0-985 On the bowl. on the top flange it has 0-834. Yes it does stall on the hillsides. (keep the tank full it helps ) Should I rebuild if i can find a kit or replace ? what carb should i use. Thanks for your help.
   / MF T035 with bad carburetor. Carter UT #2
Did anyone ever respond to your question. I have the EXACT same situation with my T035 and it seems the float got stuck cause gas was running out the bottom hole of the Carb. So, I removed the carb and disassembled it but now I am in need of gasket and might as well do a complete or partial rebuild.
   / MF T035 with bad carburetor. Carter UT #4
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2017 Genie GTH-5519 (A53317)
2017 Genie...
