J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
I agree with RANDYT , clean or replace the unloader valve itself or parts necessary
For those that don't know, the pressure/psi developed is determined by the nozzle utilized.
You probably will never see the advertised pressure while using the pressure washer. If you don't believe that, insert a 3000/3500 pressure gage in series with the hose going to the gun.
The advertised pressure is the pressure developed by the pump and the restriction used, IE, the nozzle opening, or the unloading pressure, which can be adjusted by a screw and spring. .
After the pump is running, the unloader is closed until you release the trigger on the gun. It will recycle the water into the input and you will notice the water will get warm if done long enough.
If the unloader is rusted or frozen, you could blow the pump, hose or gun, or the engine would just shut off.
One way to check the unloader is to start the PW with the trigger pulled on the gun. The engine will start and pump, but as soon as you release the trigger, the engine tries to or will shut down.
I have 4 pressure washers and have been using them for about 20 years, observing some of the problems stated. They are all Honda driven.
A 13 HP engine can pump 6.5 GPM at about 3000 psi.
A 2 HP engine can pump 2 GPM at about 1500 psi.
