Ford 1500,1700/Shibaura SD2200
   / Ford 1500,1700/Shibaura SD2200 #11
On my 1900 i replaced the factory electric gauge with a Sunpro mechanicalgauge. The sending unit screwed in to the head with out any adapters.
Bill
Thank You for all of the great responses. There is what appears to be a sending unit mounted already with a male spade on the the top. I am not sure if it was for a oil pressure gauge or for the temperature gauge that currently isn't hooked up. I don't have a picture of it at the moment but it is just above the alternator on the block...I am making the assumption this was for the temp gauge.
   / Ford 1500,1700/Shibaura SD2200 #13
FYI,
Temp sending unit.
Oil pressure sending unit on the left of dip stick.
Thanks for all the responses, the old gauge was broke as well as the sending unit. I put a universal one on from TS and all is well.
2022 CATERPILLAR 301.7CR EXCAVATOR (A51246)
2022 CATERPILLAR...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
1999 CATERPILLAR 301.5 EXCAVATOR (A51246)
1999 CATERPILLAR...
LOAD KING V6030 VERTICAL BALER (A51248)
LOAD KING V6030...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
