Backhoe Installed a new GX690 Honda but I can't get a spark?? Any suggestions??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #1
Pacifictimes
Member
Terramite T5C
T5c 2001 starter turns over, fuel cylenoid is energized, oil is on the high side, motor is grounded, positive battery cable hooked to the starter, turns over fine. Just NO spark??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #2
If you have it plugged into a ign switch disconnect it and just jump across the solenoid to crank it over and check your spark now almost sounds like you have a wire wrong also check and see if there is a on off switch on side of flywheel housing. Some had one some didnt without knowing the exact model i can tell for sure.
Hope this helps
Sam
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 JOHN DEERE 323E SKID STEER (A60429)
2018 JOHN DEERE...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
