Ford 1500 Clutch Replacement
   / Ford 1500 Clutch Replacement #1
schneidvt
Member
Summerfield, NC
Ford 1500, Kubota 4240, Ingersoll 2014
I am currently in the process of replacing the clutch on a 4x4 1500. I have sourced the clutch, pressure plate, and throwout but have been unable to locate a part # for the rear main seal. The flywheel seems to be in good condition with no gouges, are there any recomendations on other items to inspect or replace while I have the unit apart? There were no unusual noises before disassembly,just a little slip under heavy load, clutch was out of adjustment room, and after inspection there was some oil contamination to the disk. Tractor has a little over 6000 hrs on it. I appreciate any suggestions as this will be my first clutch replacement and have no manuals to rely on.
current progress
   / Ford 1500 Clutch Replacement #2
Click on this link: http://www.messicks.com/NH/65672.aspx
When the page appears, select "engine" in the menu at left. Then scroll down to crankshaft, and flywheel, and click on it. Look for #19 in the exploded view, and in the part description. Part number is listed there.
Just double check to make sure it is the right one.
   / Ford 1500 Clutch Replacement #3
Check the front seal on the transmission while it is apart.
Thanks for the info, should be able to start re-assembly next weekend. Might even get it right the first time, probably not but it's a good goal.
   / Ford 1500 Clutch Replacement #6
if you have a little oil change out your seals .. i am in the same boat right now with a MF65 only i have split mine 3 times now and still leaking need to split one more time .. had my father helping me and it went together with a bind . after he left i pulled it back found why it was binding put back together and still leaked ... with the bind i think i took out the seals again .fun fun fun ...i got it down to 45 min to pull apart lol ..good luck with yours
   / Ford 1500 Clutch Replacement #7
I would resufrace the flywheel too if you're putting a clutch in. Might as well do the job complete and do it once the right way.
the previous owner told us it had about 4000 when we got it, I doubt he would give a number that high if he wasn't telling the truth or atleast trying to. I have no doubts that numerous things have been replaced since then, i just wanted to make sure I put it in there in case there were some items that aren't usualy replaced or checked except on heavily used equipment.
Jason
2015 International DuraStar 4300 26ft. Box Truck (A51692)
2015 International...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
